2006 Corolla ECU No Label?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2012, 06:44 PM   #1 (permalink)
View thinkharder's Photo Gallery
Hi Everyone,
I have been waiting for Toyota to mail me a letter to replace my ECU on my 2006 Corolla (Recall). I got it replaced once in 08, as my Corolla had a P2716 Code.
I took apart the glove compartment box, and looked at the ECU box, but there was only a clear protective film over it, and no label indicating the actual label. Anyone know if this is normal??
edit: I looked at the service detail, and the only thing I was able to find was the Part Number: 89661-02K21 (looked it up, but without the actual serial #, cannot tell if it is part of the recall).
Thanks a bunch!
thinkharder is offline   Reply With Quote
Old 01-21-2012, 10:12 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Vehicles Covered by the Safety Recall
Model Trim Engine Trans
4-Door Sedan CE 4 Cylinder 1ZZ-FE 4AT / 5MT
Corolla ’05 – ‘08 4-Door Sedan LE 4 Cylinder 1ZZ-FE 4AT / 5MT
4-Door Sedan S 4 Cylinder 1ZZ-FE 4AT / 5MT
Matrix ’05 – ‘08 4-Door Wagon (Base) 4 Cylinder 1ZZ-FE 4AT / 5MT 4-Door Wagon XR 4 Cylinder 1ZZ-FE 4AT / 5MT
Part Number Action Part Number Action
89661-0112# Replace the ECM
89661-02K40 Replace the ECM
89661-0113# Replace the ECM
89661-02K41 Confirm the LOT Number
89661-02C0# Replace the ECM
89661-02K42 No further action required
89661-02C1# Replace the ECM
89661-02K50 Replace the ECM
89661-02C9# Replace the ECM
89661-02K51 Confirm the LOT Number
89661-02D0# Replace the ECM
89661-02K52 No further action required
89661-02D1# Replace the ECM
89661-02Q90 Confirm the LOT Number
89661-02D4# Replace the ECM
89661-02Q91 No further action required
89661-02D5# Replace the ECM
89661-02R00 Confirm the LOT Number
89661-02K10 Replace the ECM
89661-02R01 No further action required
89661-02K11 Confirm the LOT Number
89661-02R10 Confirm the LOT Number
89661-02K12 No further action required
89661-02R11 No further action required
89661-02K20 Replace the ECM
89661-02R40 Confirm the LOT Number
89661-02K21 Confirm the LOT Number
89661-02R41 No further action required
89661-02K22 No further action required
89661-02R50 Confirm the LOT Number
89661-02K30 Replace the ECM
89661-02R51 No further action required
89661-02K31 Confirm the LOT Number
89661-0Z04# Replace the ECM
89661-02K32 No further action required
Confirm the LOT number (if required)
Use the 9th through 12th digits
For OK LOT Numbers 7227 and higher:
- No further action required.
For NG LOT Numbers 7226 and lower:
- Replace the ECM.
Since it is odd that you do not have a label, enter it here: http://www.toyota.com/owners/web/pag...call_vinlookup
mikered30 is offline   Reply With Quote
Old 01-21-2012, 10:57 PM   #3 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
The label with the part number and lot number is on the bottom of the ecu under a plastic hinge towards the floor. You pull down the plastic hinge and remove the 2 clips. When you look up from the floor you will see the lot number. On the 02K21 I almost always replaced them as only like 1 had a high lot number.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 01-21-2012, 11:21 PM   #4 (permalink)
This is what it shows..not sure if I should remove the two screws that are holding the ECM..
[IMG]
Uploaded with ImageShack.us[/IMG]
Old 01-22-2012, 03:20 AM   #5 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
You're still looking above the ECU which is its bottom. It's mounted upside down. You need to look underneath ECU as seen from the floor after removing 2 clips and lower panel.
invader is offline   Reply With Quote
Old 01-23-2012, 03:36 PM   #6 (permalink)
View antalus's Photo Gallery
I bought a used corolla 2006 and the ECU hasn't part's number on the label.
I have been investigation on internet about that part's number is the correct for my car and i bought the 89661-02K53.
The car is working whit out problems
Edit: my car is mechanic transmission
antalus is offline   Reply With Quote
Old 01-24-2012, 01:21 AM   #7 (permalink)
You mean automatic transmission?
Old 01-24-2012, 11:15 AM   #8 (permalink)
Toyota Fanatic
Being from Argentina I am sure he mean manual. Mechanical or standard usually refer to a manual transmission.
My Toyota list:
Old 01-24-2012, 11:21 AM   #9 (permalink)
Mechanic, standar or manual = gearbox whit clouth pedal
Automatic= gearbox without clouth pedal
Old 01-24-2012, 11:23 AM   #10 (permalink)
That may be the case if you're familiar with Guatemalan lingo, although both manual (with clutch pedal and gear shift lever) and automatic transmissions are in fact mechanical transmissions.
Old 01-24-2012, 11:29 AM   #11 (permalink)
In fact a ECU for standard car can be used in a car with automatic transmission, just disable the module transmission.
Old 01-24-2012, 11:31 AM   #12 (permalink)
Toyota Fanatic
That may be the case if you're familiar with Argentinian lingo, although both manual (with clutch pedal and gear shift lever) and automatic transmissions are in fact mechanical transmissions.
I actually read wrong. He is from Guatemala. And the issue is that when used in everyday Spanish language there isn't really a direct translation for Manual when used to describe transmission. It is usually said
Mechanico-mechanic, Estandar-standard, or Cambio-change.
Automatic is always said Automatico.
My Toyota list:
Old 01-24-2012, 11:33 AM   #13 (permalink)
Toyota Fanatic
You would have a check engine light on always as well as issues with wiring the neutral safety switch.
My Toyota list:
Old 01-24-2012, 11:41 AM   #14 (permalink)
manual transmission (plural manual transmissions)
  1. (automotive) Mechanical transmission which shifts gears by the action of the driver's hand on the gearstick or gear lever, rather than automatically; a manual gearbox.
automatic transmission (plural automatic transmissions)
  1. (automotive) A mechanical transmission which shifts gears automatically response to speed and/or load, rather than requiring the operator to do so manually; an automatic gearbox.
Old 01-24-2012, 11:48 AM   #15 (permalink)
Hooo, thanks i don't know that issues.
PD Im from Guatemala and here Standard= Mecanico and Automatic= automatico
