Transmission Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 02:06 PM   #1 (permalink)
View ab30494's Photo Gallery
Transmission Fluid
Other then the toyota transmission fluid what brand can i use?
Synthetic or reg.
ab30494 is offline   Reply With Quote
Old 01-22-2012, 02:14 PM   #2 (permalink)
would this do http://shop.advanceautoparts.com/web...ku=#fragment-3
Old 01-22-2012, 05:43 PM   #3 (permalink)
according to advance auto i have 2 other options
http://shop.advanceautoparts.com/web...uids+and+hoses
Another question, if i were to get the toyota T-IV ATF at the dealer, any idea on what they charge per quart and case, thanks
Old 01-22-2012, 05:46 PM   #4 (permalink)
View mr1114's Photo Gallery
I just did a drain and fill on mine. I think it cost me $7 and change for each quart of T-IV
The factory ATF is the only thing I put in mine
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 01-22-2012, 05:48 PM   #5 (permalink)
that's not bad. thought it would be more expensive.
im going to replace the strainer/filter and replace all the fluid
Old 01-22-2012, 06:19 PM   #6 (permalink)
View 056bluebeater's Photo Gallery
My local Walmart has the Castrol - Import Formula at a significantly cheaper price.
056bluebeater is offline   Reply With Quote
Old 01-22-2012, 10:52 PM   #8 (permalink)
Thank you! I will be going for the valvoline one.
Old 01-22-2012, 11:15 PM   #9 (permalink)
View johnoh's Photo Gallery
I've gone with the castrol import for the last two fluid changes on my 2004 S with 165k. Transmission works fine. Would I notice any difference if I switched to one of the other fluids above? Does the high mileage castrol do anything for a car that has been well maintained? Thanks
johnoh is offline   Reply With Quote
Old 01-23-2012, 03:41 AM   #10 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Strangely enough, both Castrol ATF's have an unusually high viscosity of 8 cSt @ 100°C and 36.6 cSt @ 40°C.
Valvoline's Max Life "Suitable for use in Toyota Type T-IV applications" ATF is considerably lower than expected at 6.11 cSt @ 100°C and 26.16 cSt @ 40°C, and actually "Exceeds the latest performance requirements of DEXRON®-VI and MERCON LV® fluids" which have a relatively light viscosity.
Toyota's #08886-01705 partially synthetic T-IV ATF is likely made by Mitasu in Japan, which has a normal viscosity of 7.3 and 38.86 cSt.
Mobil's 3309 ATF is at 7.2 and 35 cSt, Amsoil at 7.5 and 38.8 cSt, and Redline at 7.5 and 34 cSt... If I was stuck with a godforsaken automatic, I think I'd go with Mobll Super (Canada's version) Multi-Vehicle ATF (7.42/34.1 cSt, 193 VI), only surpassed by Redline's 198 VI.
http://www.castrol.com/liveassets/bp...eage_06812.pdf
http://www.valvoline.com/pdf/maxlife_atf.pdf
http://jaytec-lubricants.com/index.p...=images/Toyota
http://www.mitasuoil.com/en/multi-vehicle-atf
http://www.mobil.com/USA-English/Lub..._ATF_3309.aspx
http://www.mobil.ca/Canada-English-L...icle-atf.aspx#
invader is offline   Reply With Quote
Old 01-23-2012, 11:51 AM   #11 (permalink)
View GREENPUS's Photo Gallery
Originally Posted by invader View Post
I've been using Redline products for a few years now and have not been disappointed. D4 ATF is compatible with MERCON which ford puts in their manual transmissions and this is where I first started using it. Shifts great in the ford manual tranny. Actually it's a mazda tranny but ford puts their stamp on it.
When I bought my 2005 Corolla LE I followed the directions I found on this website for flushing the auto tranny and used D4 ATF which is compatible with the corolla also. Nice thing about D4 ATF it can also be used in the power steering pumps. Great all around fluid for me. Too bad I have to order it online and can't get it locally.
GREENPUS is offline   Reply With Quote
Old 01-25-2012, 10:28 AM   #12 (permalink)
Yeah, Redline D4 ATF (7.5/34 cSt, 198 VI) is probably the best made in USA.
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
Then there's Motul Multi ATF (8.5/37.5 cSt, 214 VI).
http://www.motul-canada.com/en/produ....shtml?panel=0
USA distributor: http://www.cheapoilstore.com/english..._multiATF.html
Canadian distributor: http://www.bestpricecarparts.ca/item...ul&weight=1.95
Beside Mobil ATF 3309 (7.2/35 cSt, 180 VI), Mobil Multi-Vehicle ATF (7.42/34.1 cSt, 193 VI) is also suitable for use in vehicles that specify Toyota Type IV.
http://www.mobiloil.com/USA-English/...icle_ATF.aspx#
http://mooreballiewoil.thomasnet.com/Asset/pds18.pdf
Eneos (Japan) synthetic ATF (#W0133-1913951)
http://www.autopartsway.com/PartDeta...3-1913951/ENS/
http://www.bestpricecarparts.ca/item...os&weight=1.95
The Following User Says Thank You to invader For This Useful Post:
skippy911 (01-26-2012)
