problem in ECU corolla 2005 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2012, 07:36 PM   #1 (permalink)
View sarathrp88's Photo Gallery
Ive been having problem with my ecu of a corolla 2005 s, i purchased it at ebay since it was cheaper there than in a shop, i just want to know what is needed to be programmed in the ecu is it the inmovilizer or the key? and can a person that programs keys can do it?
how to program it please.
sarathrp88 is offline   Reply With Quote
Old 01-25-2012, 05:57 AM   #2 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
You should not need to reprogram the immobilizer or key unless you replaced the immobilizer ECU, they key, or you have some other problem related to the immobilizer. What is your problem exactly.
If you did replace the immobilizer ECU then the dealer will have to reprogram the ECU and reseed the keys. This can only be done by a master tech at a Toyota dealer. A key place can not do it.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 01-25-2012, 08:30 AM   #3 (permalink)
thanks for answering, I need to replace the ecu of my corolla 2005 I was a little expensive to buy in the dealer and decided to order it on ebay now I'm hoping that I get, and read in the forum they need to reschedule and I would like to know what I need to program, or as soon as the install in my car should run normally, or should I schedule the ignition key to the computer thanks
Old 01-25-2012, 09:28 AM   #4 (permalink)
View dorman68's Photo Gallery
The 05-08 Corollas with AT trans have a recall on the ECU or PCM, I had mine replaced for free under recall.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 01-25-2012, 01:59 PM   #5 (permalink)
Toyota Fanatic
1. Why did you buy a new ECU? I am assuming you bought an engine and ECT( electronically controlled transmission) ECU.
2. Are you aware that there are around 20 different engine and ECT ECUs available for this car depending on a range of things. And if you pick the wrong one from eBay that you may have a car that doesn't come out of gear or shifts poorly or won't start?
3. Toyota recalled the engine and ECT ECU on a lot of these cars for problems. If you need one take it to the dealership and see if you can get a new ECU free.
4. If you did buy an engine and ECT ECU and managed to get the right one. And managed to get a working ECU then you do not need to reprogram the key or worry about that. It will start and drive like normal.
5. If you replaced the immobilizer ECU then you need to reprogram and reseed the key. This can only be done by the a master tech at a Toyota dealer.
My Toyota list:
The Following User Says Thank You to hardtopte72 For This Useful Post:
sarathrp88 (01-25-2012)
Old 01-30-2012, 06:05 PM   #6 (permalink)
If i purchase the ecu what do i need to program the inmobilizer or the key please let me know the procedure
Old 01-30-2012, 06:47 PM   #7 (permalink)
mikered30's Avatar
Gameroom cash: $532567
delete
mikered30 is offline   Reply With Quote
Old 01-30-2012, 07:33 PM   #8 (permalink)
Originally Posted by mikered30 View Post
delete
Im sorry mike not quite understanding you can you be more specific
Old 01-30-2012, 09:11 PM   #9 (permalink)
mikered30's Avatar
Sorry, I responded to the wrong post.
