interesting chart from toyota - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2012, 05:19 PM   #1 (permalink)
View johnoh's Photo Gallery
A guy at bobistheoilguy got this chart in an email from Toyota. I was surprised to see that Toyota is okay with using 0w-20 in any non-XRS corolla made this century.
johnoh is offline   Reply With Quote
The Following 5 Users Say Thank You to johnoh For This Useful Post:
fj62 (02-02-2012), m715 (02-21-2012), MD1032 (02-02-2012), silver04rollas (02-08-2012), titosalvador (02-02-2012)
Old 02-02-2012, 05:24 PM   #2 (permalink)
Gameroom cash: $110300
View fj62's Photo Gallery
The oil cap on my 95 Corolla disagrees with the chart. I find the chart interesting and helpful. What oil do I use comes up often.
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Old 02-02-2012, 05:38 PM   #3 (permalink)
MD1032's Avatar
View MD1032's Photo Gallery
Interesting. If this is true, then why wouldn't we be using 0W-20 or 0W-30 oil?
MD1032 is offline   Reply With Quote
Old 02-02-2012, 07:19 PM   #4 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
0W-30 can be used in 5W-30 applications, as it has the same viscosity at operating temperature (212F).
Here's TSB EG018-06 (March 29 2006) listing engines that can use ILSAC GF–4 5W-20 engine oil, including 1ZZ-FE, and 0W-20 for some other engines:
http://www.nwfjcc.com/FJ%20Tech/eg018t06.pdf
invader is offline   Reply With Quote
The Following User Says Thank You to invader For This Useful Post:
MD1032 (02-02-2012)
Old 02-02-2012, 09:48 PM   #5 (permalink)
MD1032's Avatar
Great link, thanks for posting. It looks like they are recommending 5W-20 for the 1ZZ-FE.
I will swap out my current 5W-30 for 0W-20 and see if it makes a difference in "fuel economy" as they suggest. If nothing else, I certainly think my engine would be happier on those 10 degree mornings with the 0W.
Old 02-02-2012, 10:34 PM   #6 (permalink)
View ab30494's Photo Gallery
doed the 07' corolla CE have an 1ZZ-FE engine, Which means i can switch to 5W-20.
ab30494 is offline   Reply With Quote
Old 02-02-2012, 10:42 PM   #7 (permalink)
Originally Posted by ab30494 View Post
Does the '07 Corolla CE have an 1ZZ-FE engine, which means I can switch to 5W-20?
Yes it does have a 1ZZ-FE... You can switch to ILSAC GF–4 5W-20, especially if you're not at a very high mileage and burning oil already.
Old 02-02-2012, 11:02 PM   #8 (permalink)
Premium synthetic ILSAC GF-4/GF-5 rated 5W-20 engine oils (cheaper grades also available):
http://www.pennzoil.com/#/motor-oil/pennzoil-ultra
http://www.mobiloil.com/USA-English/...rformance.aspx
http://www.quakerstate.com/#/motor-o...ate-durability
http://www.castrol.com/castrol/secti...tentId=7067053
http://www.amsoil.com/storefront/alm.aspx
http://www.redlineoil.com/product.aspx?pid=1&pcid=21
Old 02-02-2012, 11:35 PM   #9 (permalink)
View spicyTuna's Photo Gallery
Ya I've seen this chart before. I'd still be inclined to stick with the owners manual. I figure why second guess what the manual says?
What's interesting is why does the 2012 rav4 v6 allow multiple viscosities of oil while the venza v6 for 2012 only allow 0w-20?
Sent from my Autoguide iPhone app
spicyTuna is offline   Reply With Quote
Old 02-02-2012, 11:45 PM   #10 (permalink)
Because its Toyota that is doing the second guessing
Old 02-03-2012, 01:25 AM   #11 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
This is probably caused by fuel mileage requirments between these engines. The RAV4 comes factory filled with 5W30 so going to 0W20 will only show improvement. They will only recommend lighter and never heavier. The Venza and such come factory filled with 0W20 and thus they don't want to recommend a heavier oil and when fuel economy drops they be "responsible". The only one on there that doesnt make sense is the 2007-2011 Camry V6 being able to take 5W20 but not 0W20 (even though Mobil themselves says if it can take 5W20 it can take 0W20).
I run 0W30 in the Corolla since it gets very hot in the summer and 0W20 in the Camry. There is no reason I need a thicker oil when starting. 0W is always better than 5W.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 02-03-2012, 09:34 AM   #12 (permalink)
What is the reason for not running the same in each?
Old 02-03-2012, 11:28 AM   #13 (permalink)
on full afterburner
Gameroom cash: $1345797
Agreed. I would seriously be apprehensive running a 20 weight oil on an engine that old.
Old 02-03-2012, 04:04 PM   #14 (permalink)
MD1032's Avatar
So, would 20 weight be unsafe for the 1ZZ-FE?
Old 02-03-2012, 06:41 PM   #15 (permalink)
I have just over 84,000 miles on it
