Front end noise, any advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2012, 03:06 PM   #1 (permalink)
Gameroom cash: $181900
View shoujiliuzhijun's Photo Gallery
Updated with video: Front end noise, any advice?
I heard an annoying noise from the front end of the car. Car: 2003 Corolla, 1ZZ engine, 115k miles on it. automatic
Noise: It appears to me as a rotating noise, similar as a desktop computer when it is working. It feels like something is off balance, loose or a rotating thing is hit something.
Diagnose work:
1. Jacked the front end off the ground, removed the wheels and reinstalled the wheel nuts tight to hold the rotors. I can hear the same noise when the gear is in D (not when at N, even when RPM increases) and it was increased with speed, not RPM. The noise begins at around 20 mph (or in real driving conditions 35mph). I originally thought this was the wheel bearing, but after the replacement it was still there and it seemed worse now.
2. Also, I used a long breaker bar and held against my ear at one end and steering knuckle at the other and listened. Nothing seemed terribly wrong. I also checked tie rod ends, shook the wheels, sway bar link ends, ball joint(also new), lower control arms, no play at all. All the axle boots are fine.
3. I also asked somebody else to press the accelerator and I looked for the noise. It seemed hard to locate. Also, when I sit inside the car, I can hear more noise than outside. In real driving conditions, turning or braking makes no difference.
My guess is that it was possibly the axle (bad inner CV joint?), because I've ruled out engine and tire. What do you think about this or if there's anything else I can do to check? Thanks.
shoujiliuzhijun is offline   Reply With Quote
Old 11-04-2012, 03:25 PM   #2 (permalink)
Senior TN Member
Gameroom cash: $396300
View leakyseals's Photo Gallery
There are enough reports of failed wheel bearings on TN and other sites to warrant some testing.
02 Camry XLE 2AZ-FE 268k M1 HM 5w30 10k OCI
08 Pontiac GP 3800 Series III 80k PU 5w30 OLM OCI
Both: Fram Ultra, PEA, MMO, RMI-25
leakyseals is offline   Reply With Quote
The Following User Says Thank You to leakyseals For This Useful Post:
shoujiliuzhijun (11-14-2012)
Old 11-04-2012, 11:25 PM   #3 (permalink)
04 Corolla CE manual
Gameroom cash: $473703
View invader's Photo Gallery
Audio clip?
invader is offline   Reply With Quote
The Following User Says Thank You to invader For This Useful Post:
Old 11-05-2012, 01:26 AM   #4 (permalink)
Moderator
heartdisease's Avatar
Gameroom cash: $572970
View heartdisease's Photo Gallery
Hm wouldn't a cv joint be worse turning etc? You said you replaced the wheel bearing right? I wonder if it is something in the tranny since you can hear it so much more in the car? I would think if it was something hitting as it went around you would be able to feel it in a very local spot, but I don't think I would want to be under it when it is in gear.
Hows about a little video clip?
<img src=http://i833.photobucket.com/albums/zz252/Heartdisease1/2013Chiefsresize_zpsc068a8f5.jpg border=0 alt= />
heartdisease is online now   Reply With Quote
The Following User Says Thank You to heartdisease For This Useful Post:
Old 11-05-2012, 09:09 AM   #5 (permalink)
Thanks guys, I'll post a video clip quickly when it is in driving condition.
Old 11-05-2012, 06:28 PM   #6 (permalink)
That's strange. This is the only time I carried a recorder for video&audio, but I didn't hear the noise. Will try again to capture that tomorrow.
Old 11-05-2012, 09:28 PM   #7 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $600050
View hardtopte72's Photo Gallery
The car knows you are onto it LOL!!
My Toyota List:
1982 Corolla SR-5 Hardtop 1JZGTE R154
2005 Corolla CE Manual 1ZZFE
2009 Camry LE Auto 2AZFE
If I helped out in any way please hit the blue Thanks button on my post.
hardtopte72 is offline   Reply With Quote
The Following User Says Thank You to hardtopte72 For This Useful Post:
Old 11-07-2012, 12:24 PM   #8 (permalink)
Yes! And I missed the noise the second time. I'll do another jack up and record the noise in the weekend.
Old 11-09-2012, 07:29 PM   #9 (permalink)
Update: Did another jack up with the wheels taken off and wheel nuts reinstalled. Here's the video. You can hear it when the speed is over 40 mph. I also used a stethoscope and it seems that the noise is from the passenger side. One thing I would like to add is that I can hear from the outside that the rotor makes a small metal rubbing noise, but can this be that noise when at high speed? What do you think of this noise and what else do I need to check? Thanks
Old 11-09-2012, 08:47 PM   #10 (permalink)
Can you feel it too?
Old 11-09-2012, 08:55 PM   #11 (permalink)
I don't think I can feel the shaking, only the noise.
Old 11-09-2012, 08:59 PM   #12 (permalink)
It's hard to diagnose it with that video... Can you get a video/audio of the CV axles and rotors?
Old 11-09-2012, 09:14 PM   #13 (permalink)
I will do that tomorrow. One thing I noticed is that the passenger side axle seems to rotate off center. But I grabbed on it when the speed is 0 and it is tight without play. Actually that is the No.1 thing I suspect. I just can't put the stethoscope on the rotating axle. Maybe also do some turns while the car is in the air with wheels off at 40+ speed?
Old 11-10-2012, 03:17 AM   #14 (permalink)
Toyota Fanatic
How did you rule out the tire? Who replaced the bearing? What bearing was used?
Try this to rule for certain which side its from and see if the wheel bearing is the possible culprit. If possible have a helper press the accelerator at the point the noise occurs to make sure.
Disclaimer: Myself of ToyotaNation are not liable for any injury or damage that may occur from use of this DIY. Automotive diagnosis and repair should be performed by qualified technicians. Proceed at your own risk.
1. Jack the car up with the front wheels completely of the ground and least 5 inches.
2. Secure the car on jack stands and secure the parking brake or chock the wheels.
3. Start the car.
4. After rechecking to make sure the wheels are OFF THE GROUND!!! Put the car in drive.
5. Both wheels should be turning at this point very slowly at least.
6. Carefully reach your hand between the turning wheel and fender and grab onto the coil spring with your hand.
7. If the coil spring feels smooth the wheel bearing is likely not the cause. If you can feel roughness, vibrations, or anything that isn't smooth through the spring the wheel bearing is toast.
8. Do the same for both sides.
9. Once verified press the foot brake and place the vehicle in park.
10. Shut off the engine.
11. Lower the vehicle off jack stands.
My Toyota List:
Old 11-10-2012, 09:53 PM   #15 (permalink)
This time I also took off the rotors and brake calipers. The noise was still there. With full volumn, you can here it at aroud 00:00:02 and 00:00:28. I know the belt tensioner pulley is also making a little noise, but I don't think it is the bigger noise. I also grabbed the axle again. No up/down/left/right play. A little forward/backward play (direction along the axle) is normal, right?
The stethoscope today seems to indicate the driver side is the source. I can hear a thundering noise and another noise (like you put a little stone in a bowl and rotate that bowl). These things now lead me to suspect the bearing again. I know the bearing itself can be bad, or the pressing can easily damage it. What do you think?
