wet passenger side floors - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 6 Old 11-26-2007, 12:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Has anyone had this problem? I own a 2004 Matrix and I noticed about five months ago that the rear passenger side floor was wet. I thought I had spilled something and thought nothing of it. Then about a month ago I noticed it again, and now the front pass. side floor is wet, too. I got back from a vacation a few days ago and when I got in the car there was heavy condensation on the inside of the windshield. Any ideas?
Fir Islander is offline
post #2 of 6 Old 11-26-2007, 12:31 PM
Quoted: 0 Post(s)
what does it smell like??
does it smell kinda sweet?
are you low on coolant..
if yes to any of the above questions check the heater core
chuckles is offline
post #3 of 6 Old 11-26-2007, 03:30 PM
Taco Lover
Smar969905's Avatar
Quoted: 0 Post(s)
my dad used to have an old AMC concorde (what a piece of shit that car was), and whenever it rained, the passenger side floor would always be soaked. i never quite knew where it leaked from, but feel around the door jambs and other areas in the car to try to find where water may be from.
if it is the coolant thing as suggested by chuckles, then get your car into the dealership and have them fix that immediately. that could potentially leak coolant into the oil, which will screw up the oil very badly, and could cause your motor to seize and the only way to truly fix a seized motor would be to replace it.
2011 Taco ACLB, 5mt, 4x4, MGM
Find me on TacomaWorld
Smar969905 is offline
post #4 of 6 Old 11-26-2007, 04:41 PM
Quoted: 0 Post(s)
a heater core WILL not leak oil or mix with engine oil ( that would be a head gasket)
will not seize a engine.
but might cause it to run a bit warm!
chuckles is offline
post #5 of 6 Old 11-26-2007, 05:14 PM
bc toy's Avatar
Quoted: 0 Post(s)
Maybe the AC drain tube is plugged.
bc toy is offline
post #6 of 6 Old 11-26-2007, 07:44 PM
Quoted: 0 Post(s)
its your ac drain and tube, i had the same exact problem on my 04 took it the dealer and they had it fixed in 5 minutes. the tube under the floor sometimes comes unclamped causing a large amount of water to leak into the car so make sure they use a zip tie or something to ensure it is held in place. Hope this helps
BizXRS is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
