Noise after replacing rear brake shoes and drums...help! - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
 1Likes
  • 1 Post By TallRochester
post #1 of 15 Old 01-18-2010, 04:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question Noise after replacing rear brake shoes and drums...help!
Regarding a 2004 Toyota Corolla: This is my first time using TN and need some help/suggestions with a knocking/ticking noise coming from both rear wheels after replacing with new drums/shoes. The noise becomes louder as well as faster when additional pressure is applied to the brake. Made sure the shoes were sitting correctly, that the springs are not touching other parts, that the wheels are secured tightly. Have also tried tightening and loosening the shoe width (so the drum either fits more loosely or more snug around the shoes). Has anyone had this issue? I did not replace the springs (as one toyota manual had suggested). Could this be the issue? Not sure what could be causing this.
Thank you for any and all suggestions.
CorollaSD is offline
post #2 of 15 Old 01-18-2010, 08:33 PM
03' corolla 02' tundra
Quoted: 0 Post(s)
Check to make sure you have the correct drums. Have the drums turned to make sure they are true (completely round). Change out the springs with new ones. I used orieilys springs kit pt # hdw17373 for my 03 corolla.
Note there is also a rub point that needs a small amount of brake grease. The shoes rub against the rear backer plate and need this grease. Speaking of the backer plate make sure it is not rubbing on the drum.
alligatorgar is offline
The Following User Says Thank You to alligatorgar For This Useful Post:
CorollaSD (01-19-2010)
post #3 of 15 Old 01-19-2010, 11:50 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you for the reply! I'm going to order the spring kit and double check the drums. I just assumed I was given the correct ones from the parts store, but shouldn't have "assumed." Will also try the grease on the backer plate and will post if that works.
Surprisingly, while searching the site to see if others had this problem, I came across this (may have to copy and paste into your browser):
http://www.toyotanation.com/forum/sh....php?p=2204004
post #4 of 15 Old 01-19-2010, 06:33 PM
Quoted: 0 Post(s)
I have had issue with new parts quality before. Its a drag to have to redo work because of quality issues. Check to make sure the new drums dont have a longer/thicker drum face that is scraping the back plate.
I wouldnt doubt someone in shipping dropped one of those drums and bent it. Having them turned even when new should catch a bent drum.
Allot of corollas squeak when redoing rear brakes. Check this thread out. Brake noise, squeak
Btw how many miles you have on the corolla now? I changed out my shocks, front bearings at 90,000 miles because of excessive tire wear.
CorollaSD (01-20-2010)
post #5 of 15 Old 01-19-2010, 08:13 PM
Quoted: 11 Post(s)
Make sure your drums are machined in far enough. I had this problem on a different vehicle. The edge of the shoe would get grabbed by the edge of the drum and tweak it a little until the spring would pull it back. You could try filing down the outside of the shoes where they are near the drum as well. If you have your old drums/shoes you could have them measured for width and see which is the problem if this is it.
olbus is offline
The Following 2 Users Say Thank You to olbus For This Useful Post:
CJCride (01-19-2010), CorollaSD (01-20-2010)
post #6 of 15 Old 01-20-2010, 11:11 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Alligatorgar - I currently have just over 100K on my Corolla. Will be working on this issue over the weekend. So frustrating since this will be the 4th time I've had to play around with them but the clicking noise is about to drive me insane! Thanks for the feedback.
Olbus - Great suggestion as well. Regretfully, since this wasn't my first rodeo with brakes, I discarded my old drums/shoes (lesson learned). I'm hoping that I can visually see if this is an issue.
post #7 of 15 Old 01-21-2010, 07:59 PM
Quoted: 0 Post(s)
I had the same problem with the front brakes. I ended up bringing pads back and swapping them out. It solved my squeaking problem. Defective pads.
post #8 of 15 Old 01-21-2010, 08:43 PM
Bitter's Avatar
Quoted: 1506 Post(s)
grease or oil contamination on the brake shoes can cause a sound like that as well.
Bitter is offline
post #9 of 15 Old 02-23-2013, 12:11 PM
Quoted: 0 Post(s)
Sorry folks, there is no reason why grease would continue to cause a clicking noise in the brakes. Eventually it will evaporate enough to not be present. Usually clicking denotes a hard physical contact between two parts. I just replaced the rear drums and pads on my friends 2003 Corolla. She thought they felt softer than before so I figured I had not bled them enough. So in one week she brought it back for me to work on again and she complained that there was a clicking noise in the brakes.
So I bled the them and made sure everything was still where it should be. After that I took it for a test drive they were much tighter but the right rear was still clicking! I had bought high end quality drums and pads so I did not believe that there was any issues there. What dawned on me was that if the entire unit was not quite centered and set correctly something could be making physical contact and clicking. So my solution was to drive the car backwards pretty fast and stop it a couple of times. Well that fixed it.
Of course we will see if it comes back but compared to a lot of cars that I have worked on these little rear brake drum systems rely on the whole system to be centered correctly between the tire, wheel, drum and backing and pads, and if any of those things are not quite lined up it makes sense that something would be physcially contacting something else which would make a definite clicking sound.
Truckboy is offline
The Following User Says Thank You to Truckboy For This Useful Post:
MD1032 (10-03-2013)
post #10 of 15 Old 02-23-2013, 02:06 PM
Bitter's Avatar
Grease or oil contamination does cause clicking sounds. Here's why:
1. It impregnates into the drum braking surface and creates a spot with different physical properties, like a hot spot on a rotor would. In fact the same thing can happen to a brake rotor.
2. It impregnates into the brake shoe lining and does the same thing as it does to the drum. One shoe has a spot that is more slippery than the other shoe, so one shoe grabs harder and will pop on the backing plate instead of them shifting together.
There are compounds in grease which modify friction that do not just evaporate, grease is an emulsion of heavy oils and solids like graphite and molybdenum oxides/sulfides which are high pressure lubricants.
Bitter is offline
The Following User Says Thank You to Bitter For This Useful Post:
MD1032 (10-03-2013)
post #11 of 15 Old 10-03-2013, 11:24 AM
Quoted: 0 Post(s)
clicking rear brakes
Make sure your parking brake cable is behind the retainer in the drum other wise the back of the wheel studs will hit the cable. Drove me nuts also. Cost me 2 sets of shoes and hardware till I found the problem.
wernerh is offline
post #12 of 15 Old 07-22-2014, 10:33 PM
Quoted: 0 Post(s)
I have a similar problem. The ticking noise is as I stop... Not while I'm driving. What might that be?
staton4 is offline
post #13 of 15 Old 07-26-2014, 06:53 AM
New Corolla XRS user
REN69's Avatar
Quoted: 92 Post(s)
as my neighbor says, rule of thumb... if you're putting new drum brakes, do you really want the old hardware in there rusting away? buy the new springs and replace it all at once.
Follow my Celica Supra Antics on Facebook ---> HERE!
REN69 is online now
post #14 of 15 Old 06-09-2015, 12:32 PM
Quoted: 0 Post(s)
Tall Rochester
I experienced rear shoe brake clicking/clacking with an older Saturn. After checking the emergency brake cable and taking apart my brakes numerous times, switching shoes and drums I was puzzled that there was no change. The brakes were adjusted properly, new springs, shoes, rear cylinders, drums, the six points lubed and the wheels moved freely with the car jacked up.
Next I took my small magnetic bullet level, placing it on the spindle hub next to two of the wheel mounting studs I checked the distance to the edge of the brake mounting plate at 12, 3, 6 and 9 o’clock positions to my level. At the 6 o’clock position the plate was bent inward approximately 3/8 inch. This change in the mounting plate plane compared to the brake drum plane caused the brake shoes to be moved off the mounting plate and to be banged back against the plate causing the clicking or clacking noise.
I used my wrecking bar and pried against a rear suspension knuckle to bend the mounting plate until the distance between the level and plate edge were equal in all positions. On the next test run the clicking noise was gone. Now I always check to be sure the planes are correct. Hope this helps.
John Anthony likes this.
TallRochester is offline
post #15 of 15 Old 06-09-2015, 01:37 PM
Quoted: 84 Post(s)
Havent read the thread yet since im at work, but I just wanted to say I also got a clicking that sounds metal on metal coming from rear passenger side when I apply the brakes hard, but I think it went away I gotta give it a listen today with the window open.
it starter after i got brakes serviced at a mechanic so the guy musta goof'd.
2005 Corolla
potatomon is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
« Back
