2004 Corolla CODE PO 420 137,000 miles - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 6 Old 12-13-2010, 08:43 AM Thread Starter
2004 Toyota Corolla
Quoted: 7 Post(s)
(Thread Starter)
Went to Toyota with an engine light. They said the code was PO 420 and i needed a catalytic converter and new front and back washers. They wanted 1500 to replace.
Where can I get a decent price converter and washers? I have a mechanic that charger $15 an hour to work on my car. I normally take to Toyota to get a diagnostic but buy somewhere else and let my mechanic put the stuff on.
Thanks
billisnice is offline
post #2 of 6 Old 12-13-2010, 12:08 PM
Quoted: 0 Post(s)
Use this link to read the earlier post on this topic.
2004 Corolla P0420 Code
I used Walker direct fit exhaust parts to replace the cat. converter. They have a five year, 50K mile warranty. You can buy them at local parts store or online for about $300-400. Don't go cheap with the generic converters for under $100. You'll regret it.
When you say 'front and back washers' did you mean front and back oxygen sensors? Those sensors are recommended to be replaces after 100,000 miles and are often replaced at the same time as the cat. converter. They are available at most auto stores and cost $75-100 each for direct fit replacements.
aspen007 is offline
post #3 of 6 Old 12-14-2010, 08:44 AM
Quoted: 4 Post(s)
I agree with aspen007, buy a good aftermarket converter as the cheapie genereic ones will haunt you in the near future.
05 Corolla LE -AT- 1ZZFE - 137,000 mi
08 Corolla LE -AT- 1ZZFE - 164,000 mi
05 Vibe - AT - 1ZZFE - 137,000 mi.
97 Tacoma - 2WD - 4CYL - 84,000 mi
dorman68 is offline
post #4 of 6 Old 12-14-2010, 10:05 AM
Senior TN Member
Quoted: 141 Post(s)
Are they positive that code is for the cat and not for the back O2 sensor?
mikered30 is offline
post #5 of 6 Old 12-16-2010, 01:19 PM Thread Starter
2004 Toyota Corolla
Quoted: 7 Post(s)
(Thread Starter)
strange
The check engine light went out a couple days ago...As long as out i am not going to worry. Any additive i can add to the gas to clean the pipes out?
thanks
post #6 of 6 Old 01-02-2011, 04:31 AM
Quoted: 1 Post(s)
Well, i wish my P0420 code would go away.
I'm down to replacing my cat. Already replaced spark plugs, and downstream O2 to no luck but still pass emissions with
flying colors.
See with a P0420, it doesn't take much to set it off.
Also there is no additive to clean the the pipes out if not make it worse.
ryfly is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
