What lug nuts do I need? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 6 Old 04-16-2012, 02:37 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I have a 05 Corolla with steelies and acorn lug nuts. I'm putting on a set of Celica GTS wheels but not sure what kind of lug nuts I need.
Should I be looking at 12X1.5 mag lug nuts with 13/16" hex head with a standard shank? Correct me if I'm wrong.
Also Rockauto sells Dorman lugs, has anyone ever used them? Not looking for anything fancy, just don't want them to rust in a couple of years. Or should I upgrade to the professional grade lugs?
thanks
ajm2881 is offline
post #2 of 6 Old 04-16-2012, 03:55 PM
Quoted: 48 Post(s)
Celica GTS rims take OEM lug nuts
onemph05 is offline
post #3 of 6 Old 04-16-2012, 04:49 PM
Toyota Fanatic
hardtopte72's Avatar
Quoted: 1609 Post(s)
You need OEM washer lug nuts. Any Toyota with OEM alloys from around 1995-2012 should work as long as its not a 2007-2012 Tundra. 2008-2012 Sequoia, 1998-2012 Land Cruiser (5 lug 5X150). BBS and Enkei do not count as OEM alloys.
My Toyota List:
1982 Corolla SR-5 1JZGTE M/T
2005 Corolla CE 1ZZFE M/T
2005 Sequoia Limited 2UZFE A/T
If I helped out in any way please hit the Thanks button under my post.
hardtopte72 is offline
The Following User Says Thank You to hardtopte72 For This Useful Post:
ajm2881 (04-19-2012)
post #4 of 6 Old 04-19-2012, 11:16 AM
Quoted: 3 Post(s)
I did the same thing upgrading from steel rims to Matrix rims. I ended up biting the bullet and getting the lug nuts from the dealer and was super pricey. Luckily they took pity on me and gave me a slight discount.
Ordered Chaos is offline
post #5 of 6 Old 04-19-2012, 06:37 PM
ASE Certified Master Tech
Quoted: 35 Post(s)
It depends on the seat type of the wheel. Most likely it will be either conical or flat:
If conical then any 12mmX1.5 lug nut should do - even the original lugs. Make sure it is a 21mm hex (means a 21mm wrench fits it which is very close but not the same as 13/16"). You can use an open lug such as the following Dorman lugs:
611-866
or 611-066
You can also use chrome capped lugs such as 611-133
If the wheel uses flat type lugs then you need washer type lugs like these:
611-211 (Stainless)
or 611-117 (Chrome)
I've used Dorman lug nuts for years with no ill effects. They are good quality and last a long time.
MasterTecInSTL is offline
The Following User Says Thank You to MasterTecInSTL For This Useful Post:
post #6 of 6 Old 04-19-2012, 07:23 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I've already ordered the 611-211 lugs, hopefully I picked the right ones. Rockauto shows all 3 types of lugs for my Corolla, but for a Celica they do not show the conical lugs. So by process of elimination, I ruled the conical lugs and I already know the acorn lugs wont work.
The only question I had was the length of lugs I needed because for celica's there are 4 choices on Rockauto (32.5, 36.5, 37, and 47mm) and for corolla there are 36.5 and 37mm.
I picked the 36.5mm lugs.
ajm2881 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
