06 Matrix temp gauge fluctuating - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 3 Old 10-22-2012, 10:35 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have an 06 Matrix with roughly 169K, suddenly this week I noticed that the temperature gauge will go high like overheating and then drop back down to normal, then slowly rise and then go back down. There is no consistency on when it does it, sometimes happens right when I crank it up, sometimes after I have been driving for half hour during my commute. Sometimes when accelerating, sometimes when stopped. Can run the heater on open speed, defrost and doesn't seem to make a difference. Can't tell if the engine is actually overheating or if just gauge. Just got oil changed on Friday, didn't seem to make any difference, all fluids were full when had changed. Husband seems to think it is the thermostat, but can't find anything online that confirms.
whaleybug is offline
post #2 of 3 Old 10-22-2012, 03:14 PM
Gearhead
Quoted: 45 Post(s)
A stuck thermostat can cause those sort of symptoms. Anywhere from not getting up to temp to overheating in a heartbeat. Only way to test this, is to pull the thermostat and see if it is stuck open. If it looks OK, then you'll need to test its operation, i.e., drop it into a water bath, heat it up and see that it opens at the correct temperature.
There are also number of other possible culprits here. From a faulty engine coolant temperature sensor (ECT), bad electrical connection(s), faulty ECM, etc. Have to do some diagnostic work to rule these out one at at time, whatever is left is likely the true cause of the issue.
2002 Toyota Corolla S
2003 Toyota Matrix XRS (RIP)
2009 Toyota Matrix XRS
2009 Toyota RAV4 Limited AWD
2016 Toyota RAV4 XLE AWD
fishexpo101 is offline
post #3 of 3 Old 10-24-2012, 07:29 PM
Quoted: 106 Post(s)
If it does it on a cold start then it's not the thermostat, not really overheating.
It's a bad temp sensor, shorted wiring or the gauge itself.
circuitsmith is online now
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
