Valve cover gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 13 Old 02-09-2013, 05:57 PM Thread Starter
Quoted: 58 Post(s)
(Thread Starter)
Valve cover gasket?
I changed my spark plugs on my 07' corolla, with 118k miles on it. it looked like there was a little bit of oil on 2 of the coil packs. not alot. it was about where the gasket is. it smelled like oil, felt more like grease. spark plugs were clean. spark plug wells were clean to.
in one of the spark plug holes, where the valve cover gasket is, looks like a drop of oil. So if anything it may be a very small leak, if even that.
Should i just go ahead and replace the gasket just to be on the safe side.
ab30494 is offline
post #2 of 13 Old 02-09-2013, 06:04 PM
Senior TN Member
MD1032's Avatar
Quoted: 71 Post(s)
I think it would be worth it for peace of mind. Relatively cheap and easy to replace.
2005 Corolla S - sold
2012 Mazdaspeed3
1994 Mustang failmobile
MD1032 is offline
post #3 of 13 Old 02-09-2013, 06:25 PM Thread Starter
Quoted: 58 Post(s)
(Thread Starter)
ya thats what i was thinking, plus it would be a pain to clean it up if it did start leaking more
ab30494 is offline
post #4 of 13 Old 02-10-2013, 07:36 PM Thread Starter
Quoted: 58 Post(s)
(Thread Starter)
didn't want to make a new topic for this.
will a vacuum leak cause bad has mileage
ab30494 is offline
post #5 of 13 Old 02-10-2013, 09:08 PM
04 Corolla CE manual
Quoted: 604 Post(s)
There won't be a vacuum leak at valve cover gasket, just oil leaks... A vacuum leak at intake manifold gasket would have little effect on fuel efficiency. Original black gasket is likely leaking by now, causing a slight lean condition and erratic idling. Replace with Toyota's revised orange silicone gasket # 17171-22060.
invader is online now
post #6 of 13 Old 02-10-2013, 09:11 PM Thread Starter
Quoted: 58 Post(s)
(Thread Starter)
Ya I am having not very good gas economy. and it's really cold out. the engine is louder than itshould
ab30494 is offline
post #7 of 13 Old 02-26-2013, 06:03 PM Thread Starter
Quoted: 58 Post(s)
(Thread Starter)
did want to start a new thread for this. But from what i read, i think im right
just got a check engine light today. code is P0171, lean
My guess is replacing the intake manifold gasket will prob fix this
ab30494 is offline
post #8 of 13 Old 02-27-2013, 06:31 AM
Quoted: 0 Post(s)
Do you need to drain motor oil before replace valve cover gasket?
Kennyc23 is offline
post #9 of 13 Old 02-27-2013, 06:32 AM
Quoted: 604 Post(s)
No.
post #10 of 13 Old 02-27-2013, 06:36 AM
Quoted: 0 Post(s)
Thanks Invader. how about spark plugs? do i need need to remove them?
Kennyc23 is offline
post #11 of 13 Old 02-27-2013, 06:41 AM
Quoted: 604 Post(s)
No... Follow steps 1 to 6, and 15 to 18.
While you're in there, you could also measure your valve clearances.
http://madstyle1972.com/Repair/14/201lbc05/a040001.pdf
post #12 of 13 Old 02-27-2013, 06:57 AM
Quoted: 0 Post(s)
Besides 08826-00080 seal packing. what equivalent product do you reccommend?
Kennyc23 is offline
post #13 of 13 Old 02-27-2013, 06:59 AM
Quoted: 604 Post(s)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
