battery light back with new alternator - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 9th Gen/1st Gen Matrix (2003-2008) 9th generation Corolla and 1st generation Matrix discussion.
post #1 of 12 Old 12-04-2013, 08:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 03 Corolla LE with an auto trans. The battery light came on, sometimes it would stay on and other times it would flash or go out for a time. I hooked up a volt meter for a few day and found out that the alternator was over charging, it would run from 15 to as high as 17 volts.
I put on a new alternator last week and the light was off for a few days, then it came back on and stayed on for the last 3 days. I put the meter back on it for the past few days and the alternator seems to be working perfectly, from just under 14 volts to about 14.5 at all times.
The only other strange thing that's been going on is the daytime running lights haven't been coming on. Could the relay for the lights be causing this? Thanks for any help.
sparkie561 is offline
post #2 of 12 Old 12-04-2013, 08:10 PM
Got Pyro?
funman1's Avatar
Quoted: 437 Post(s)
I wonder if the over voltage fried some electronics?
Professional Pyro..
No really; I get paid to blow stuff up...
funman1 is online now
post #3 of 12 Old 12-05-2013, 05:29 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
thanks
post #4 of 12 Old 12-05-2013, 07:38 AM
GREENPUS's Avatar
Quoted: 46 Post(s)
most replacement alternators are rebuilt and it's pretty common to get a bad one. I'd take it back
GREENPUS is offline
post #5 of 12 Old 12-05-2013, 10:47 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
not rebuilt
It's new, not a rebuilt and the voltage output has been perfect. Why would you think that it's defective?
post #6 of 12 Old 12-05-2013, 02:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
update, went crazy again
I just got into my car to go into town. Right after I started it up I noticed the battery light was off and the daytime running headlights came on. Then I looked down at my meter and the voltage went up to 18 volts, the light flashed a couple of times then stayed on again. By the time I got back the voltage was normal and the light was on. I'm going to take it in to Advance auto parts (where I bought the alternator) and let them test it. I don't know if they will be able to find anything unless its acting up at the time.
post #7 of 12 Old 12-05-2013, 02:19 PM
Quoted: 8 Post(s)
How old is the battery? Has it been tested?
thatoneguy is offline
post #8 of 12 Old 12-06-2013, 04:23 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I'm going to do that. I've had the car 5 years and haven't replaced it yet. I don't know when it was installed.
post #9 of 12 Old 12-06-2013, 06:33 AM
Quoted: 4 Post(s)
I have had bad luck in the past with new aftermarket alternators in my former vehicles. I ended up going with a good used one and that cured my issue. Did you use new aftermarket or new OEM unit? Hope this helps.
05 Corolla LE -AT- 1ZZFE - 137,000 mi
08 Corolla LE -AT- 1ZZFE - 164,000 mi
05 Vibe - AT - 1ZZFE - 137,000 mi.
97 Tacoma - 2WD - 4CYL - 84,000 mi
dorman68 is offline
The Following User Says Thank You to dorman68 For This Useful Post:
GREENPUS (12-06-2013)
post #10 of 12 Old 12-06-2013, 08:32 AM
GREENPUS's Avatar
Quoted: 46 Post(s)
If it's new and an OEM from toyota then I"d think the alternator is good. If it's an aftermarket, then yes, I would not trust it.
GREENPUS is offline
post #11 of 12 Old 12-06-2013, 08:34 AM
GREENPUS's Avatar
Quoted: 46 Post(s)
yup! Most are rebuilt in some 3rd world country and shipped here. Pure garbage...
GREENPUS is offline
post #12 of 12 Old 12-06-2013, 10:03 PM
Quoted: 9 Post(s)
Just a thought: are your battery cable connections secure at both ends of each cable? (...and also the larger ground connections such as engine-to-body) If your battery circuit is going open occasionally while driving, the car won't go dead (since you're using on-board power from the alternator), but your voltage regulator might go bonkers (to use the scientific explanation ) trying to deal with a charging circuit of suddenly-infinite resistance.
Andy Green
2005 Corolla S
2005 XLE AWD Limited
acg_sienna is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 9th Gen/1st Gen Matrix (2003-2008)
User Tag List
Linear Mode Linear Mode
Back
