Re: For those whose A/C only works on hi
Sir F. A. Rien <jaSPAMc@gbr.online.com> wrote:
[color=blue]
>On Sat, 08 Jul 2006 23:03:39 -0700, [email]nospam@hm.pls[/email] (Randy) found these unused
>words floating about:
>[color=green]
>>[color=darkred]
>>>It doesn't "use" freon ... the refrigerant is in a closed system (or should
>>>be!).[/color]
>>But eventually people need to add refrigerant because ... ? It just
>>breaks down over time chemically?[/color]
>Usually minute cracks that you can't 100% seal. That's why they make a
>'sealant' version for older vehicles. The heat/cold swings as well as
>vibration make it inpossible to maintain a perfect seal.
>I've an Amana roof A/C unit that's 20+ years old, never been touched and is
>still meeting every performance check. How often do you add freon to
>refrigerators? They're about the same as a car's system in size.[/color]
Great point.
[color=blue]
>By "USE" I meant as in consume, the OP commented that altering the
>temperature might "use less freon'.[/color]
Thanks for the explanation. I won't feel like I'm using up the
refrigerant now when I run the A/C. :) I don't want to be forced to
replace this A/C b/c it works so good (and of course the expense). But I
was thinking the more I use it the sooner the freon (or whatever they
use in these old ones) will be gone. But if it is only dependent on
leaks then it makes no never mind! :)
