Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - GTS differences each year
View Single Post
Old 07-09-2006, 09:19 PM   #9 (permalink)
silver04rollas
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
I would recommend having it checked by a mechanic when you get it inspected.
As for fly by wire vs cable, fly by wire is electronic driven throttle that is controlled by the computer while cable is directly linked through a cable so there is no computer intervention. The problems with fly by wire throttle is that there is a 1 - 2 sec throttle lag due everytime you rapidly give inputs or suddenly press the pedal and other problem is that the aftermarket support would be limited on the fly by wire models.
Originally Posted by rp02_aw11
how could you check the lift bolts? aren't they below the valve cover? and is lift bolting breaking a really common problem?
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
