Re: Right stuff to clean garage floor - heavy oil.
On Thu, 13 Jul 2006 22:54:03 -0500, Ray O wrote:
[color=blue]
> "joe" <nonspam@invalid.com> wrote in message
> news:1a4db25bta4ev1ujtgeqpo1j0m267omesh@4ax.com...[color=green]
>> Just got done with cleaning two garage spaces (sold vehicles). The
>> oil leaks from 25 years of parking was severe.
>> Used TSP - poor result - failed even to cut the grease.
>> A heavy duty degreaser and cleaner - not much better.
>> Laundry detergent - no worse than above.
>> 87 octane gasoline - absolutely the best - but also extremely risky.
>> Used about 1-2 cups at a time (total used about 1 gal) with some
>> water and heavy brushing. Did a bunch of rinsing to get rid of fumes.
>> Gas did the best job.
>> Prior to this I did a google and found nothing. Is there an available
>> cleaner that will dissolve dryed oil 1/8 in thick in places - other
>> than gasoline and the associated extreme risk in an attached garage?
>> Just in case I need it in another 25 years <grin>.
>> j[/color]
> Using gasoline on your garage floor can get you into the running for a
> Darwin Award.
> Having driven Toyotas/Lexus since 1978, I have not had to deal with stains
> from oil leaks so I don't have much advice to offer on getting rid of floor
> stains.[/color]
Obviously, Ray hasn't driven too many Supras...
We have now begun overheating. This is not a good sign, esp since the
previous owner spent $1000 on the cooling system...
There is one caveat: I removed the drip pan/cover from the bottom of the
car in the early spring. Today I was looking at the radiator, etc, when I
noticed most of the airflow for the radiator comes from openings in the
air dam. From the looks of things, it looks like the drip cover also helps
channel air to the radiator; without it the airflow probably goes under
the engine, missing the radiator by quite a bit. I think I'll reinstall it
tomorrow morning...
But, an overheating Supra is NOT a Good Thing...
