Originally Posted by frotou
Badza ,
I think we can talk for hours about our setup  .
My cam gear are something like -8 and -5 degrees to be at tdc with the crank. I will recalculate later as I wait for a complete new race head and new cams.
1-For the clutch kit , if you live in New Zealand and the quarter master are made in USA I paid twice the shipping ?
2-Let me know also your delay for the whole kit and compatibility with different tranny. (I currently have stock celica 7afe trans. but I dream to have one 4agze builded like yours).
3- You are not affraid about harmonical vibration to the oil pump gears by using aluminum crank pulley ?
Claude
Claude,
1. I can get my supplier to send it directly to you from the USA for the clutch part. You will save around $40USD this way as thats what it costs to ship to my country, but then save more on shipping from my country to you as the parts will weigh less. You still will have to pay for shipping of the flywheel, bearing and cradle. I will get a quote to ship the flywheel & bearing to USA.
2. If your using the 7afe trans then the spline on the clutch would need to be the smaller size, therefore not compatible with the gze gear box spline. So you need to decide what to choose as the RY plates in these clutches are not cheap to change.
3. I actually dont use a alloy pulley I use a stock 20v one with the center part changed to billet steel (yes on the 20v blacktop you can press the center out), as the stock centers after a while crack and then your crank key falls out resulting is disaster. I also make and sell these centers.
regarding the timing being out, I can re-key the crank sprocket to bring the timing back to where it should be, I only charge $60NZD to do this.
