Starter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2007, 02:16 PM   #1 (permalink)
View zekelander's Photo Gallery
Starter
I have a 1990 sedan 1.6L corolla that won't start. It is weird because it will start, but if i drive it for more than 20 Min and shut it off, it won't start. I have changed the battery, the negative battery cable, the positive battery connector, I have had two aftermarket starters installed, and still no luck. I am leaning towards the starter getting heat soaked but after it did it with the second one i installed, i have doubts. I turn the key and no clicks or anything.
zekelander is offline   Reply With Quote
Old 06-13-2007, 02:20 PM   #2 (permalink)
View wiccanferret's Photo Gallery
If you're not getting any clicks I would check the ignition switch itself. Even a heat soaked starter generally clicks.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 06-13-2007, 04:50 PM   #3 (permalink)
View tashirosgt's Photo Gallery
Run a temporary ground wire from the negative battery terminal to the block. If it starts with this arrangement, replace the negative battery terminal wire and when you do this run a permanent ground wire from the frame to the block.
tashirosgt is offline   Reply With Quote
Old 06-13-2007, 05:56 PM   #4 (permalink)
View woodenhead72's Photo Gallery
u can also try running a temp wire from the solenoid wire on the starter and just direct connect to the battery + once the car wont start again, if it starts then its most definately something in the wiring or the key switch.
woodenhead72 is offline   Reply With Quote
Old 06-13-2007, 10:40 PM   #5 (permalink)
View toyota_b's Photo Gallery
>-------It is weird because it will start, but if i drive it for more than 20 Min and shut it off, it won't start.
My t- bird's alternator was shot and this is what it would do... Have you checked the alternator?
toyota_b is offline   Reply With Quote
Old 06-14-2007, 09:36 AM   #6 (permalink)
I suggested the switch because I'm wondering if there's some jostling involved. But woodenhead's idea is a foolproof way to narrow it down at least that much.
Old 06-15-2007, 01:14 AM   #7 (permalink)
View broke's Photo Gallery
Auto tranny or manual. Maybe a loose wire to the park/neutral sensing switch
broke is offline   Reply With Quote
Old 10-20-2007, 06:17 PM   #8 (permalink)
View kennman475's Photo Gallery
Did you ever get this fixed? If so, what was the problem? I am having the EXACT same problem.
Kennman475
1991 Corrolla DX
http://www.ryleejames.com
kennman475 is offline   Reply With Quote
How to test Starter? Help plz car_boy_16 1st & 2nd Generation (1983–1986 & 1987-1991) 8 06-23-2007 02:47 AM
saved some cash on starter problem wudshapr Pre-88 Toyota Pickup/Hilux 1 05-06-2007 12:16 AM
3.4L V6 Starter Problems - A Follow-Up toto 1st Generation (1995.5–2004) 0 05-27-2006 03:42 PM
Need Help With Starter Eye8Pussies General Discussion 9 05-24-2005 04:58 PM
Starter Problem clauser Camry & Solara Lounge 2 03-09-2005 07:50 AM
