A 92 corolla DX wagon into a tuner car ANY HELP...PLEASE READ - Page 11 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 08:45 PM   #151 (permalink)
8th generation slowness
SlowRolla37's Avatar
View SlowRolla37's Photo Gallery
im getting it from ebay. if you go to ebay and type in chrome lettering. you should find some things. there like 1.09 a piece for the abs plastic ones and 5 dollars a piece for real chrome ones.
SlowRolla37 is offline   Reply With Quote
Old 09-10-2007, 08:47 PM   #152 (permalink)
View Awheet's Photo Gallery
How do i get off the old lettering??
Awheet is offline   Reply With Quote
Old 09-10-2007, 09:13 PM   #153 (permalink)
im not quite sure how to safely remove that lettering. i bought my car without the lettering.
Old 09-10-2007, 09:33 PM   #154 (permalink)
KhmerXboyXnoy
ae92Xtruen0Xsr5's Avatar
View ae92Xtruen0Xsr5's Photo Gallery
umm just a suggestion...wouldnt sum kind of thinner help or mabe sum gasoline...ive used gasoline for plenty of different types of removing mabe u should try sumthing lyk that mabe???if it dont work...mabe sumone else has a better idea...
I am a fat man...With fat dreams...How far will you go yo?...
89'Ae92 Sr5 corolla...4Af Carbed...
93'EG civic coupe...D16z6 V-tec
ae92Xtruen0Xsr5 is offline   Reply With Quote
Old 09-10-2007, 10:33 PM   #155 (permalink)
View LChineze's Photo Gallery
turbo kit??? why not just swap in the 3SGTE motor? turbocharging an 4AFE would be a waste cause the potential of that motor is nowhere near the potential of the 3SGTE. since it is already turbocharged, the engine internals are designed to handle the stress and power output. then upgrading the turbo would be a much easier process and you won't have to worry about snapping or blown connecting rods. swapping the motor would trump every modifcation you have listed other than the suspension upgrades. things like tint, paint job, sun visors, petals, engine degreaser, shift boot, and stereo deck are all merely cosmetic changes. if you need sunvisors, why not just go to pick-n-pull and grab one? after swapping in the 3SGTE, you wouldn't need a cd stereo deck cause the revving and blow off valve would be music to your ears.
i wish i had known about motor swaps when i first started driving. i didn't know about the 4AGE 20V then, but if i did, i would have definitely done that instead of buying my stereo components and other cosmetic stuff.
if you truly want your car to be a tuner car, better yet, a sleeper tuner car, i highly suggest motor swap. check out the 3SGTE or the 4AGZE (supercharged) to see if you are interested....just think about it...
LChineze is offline   Reply With Quote
Old 09-10-2007, 10:47 PM   #156 (permalink)
KhmerXboyXnoy
Lchineze does prove a point...but...like we all been saying just go with wat ever man...Because i have a 4af motor a downgrade from urs because urs is fuel injected and mine is carbed...and i plan to stick with my motor and upgrade slowly to moneys contempt...but hey A 4agze is a pretty kool motor man...but its up to u anythings possible dood jus use ur imagination...back then i was thinking of putting a Sr20 motor in my car because a friend of mine a great car enthusiest told me anythings possible and was going to help me put it in if i baught the motor and the right components for it and u knoe wat it was going to be a rear wheel drive conversion too...and i do oh so luv drifting very much...Well its up to u thats mai side of the story...
Old 09-10-2007, 10:53 PM   #157 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
Originally Posted by Flashmn
Thats very far fetched. Maybe you should tell that to porsche or ferrari
Heck, put in a good word for cross-drilling's reliability to NASCAR and F1, I'm sure they just haven't thought of it yet and that's why they don't use it...
If he's dead set on anything other than Brembo blanks, though, going slotted is probably at least going to get him better quality parts than Billy Bob's Custom Drilled While-U-Wait Rotors.
With respect to the debadging, GooGone, a hairdryer, and dental floss works pretty well...
WIP AE102.
Piloter is offline   Reply With Quote
Old 09-11-2007, 05:11 AM   #158 (permalink)
how hard would an engine swap be if i didi it myself and where can i find a motor
Old 09-11-2007, 06:38 AM   #159 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
F1 uses carbon brakes and nascar outdated technology, quite the opposites. Nascar for example states, that you can have one set of pads per wheel (quite normal), but one piston per caliper and no abs.
And quite frankly comparing all out track cars to street cars is like comparing chokolate to shit, they both look similar, but they're totally different on the inside
Old 09-11-2007, 07:06 AM   #160 (permalink)
View lazydog's Photo Gallery
My old wagon
Here are some pics of my former wagon project I did a couple of years ago. We tossed out the old engine and together with some of my buddies swapped in a 4efte. Just like to share them... good luck with your project.
more pics here: http://www.cardomain.com/id/kp_61
lazydog is offline   Reply With Quote
Old 09-11-2007, 03:30 PM   #161 (permalink)
that car has some exterior potential.
Old 09-12-2007, 03:54 PM   #162 (permalink)
ok so i took off my corol badge from my car and there is like some wired foamy shit left in its spot i used rubbing alcohol and dental floss but no hair dryer. I also have a sign of the fixh thing on my car from when my mom had the car how do iget the foamy shit off from underneath it
Old 09-12-2007, 04:45 PM   #163 (permalink)
KhmerXboyXnoy
yea dood i believe thats where the gasoline comes in...thats wat i used...just use a rag and soak it in some gasoline then scrub like crazy in circular motion...
WAX ON WAX OFF MR.MIAGIE
Old 09-12-2007, 06:13 PM   #164 (permalink)
awheet lets see some pics of this wagon!
Old 09-12-2007, 08:07 PM   #165 (permalink)
Hey guys i have an idea i saw a post on here abput a guy wanting a deep exhaust and people told him to take his muffler off...I have a blot on stock muffler should i take mine off would that give me a deep sound or a hi pitch sound
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Gas Mileage stumpfoot Pre-88 Toyota Pickup/Hilux 17 08-03-2007 01:42 AM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
