Distributer O ring leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2007, 10:12 PM   #1 (permalink)
View toyo47's Photo Gallery
USA Distributer O ring leaking
I own a 1990 toyota corolla LE, the dealer states the distributers O ring is leaking what affect if any would this have on my vehicle?
Dealer wants 125$ dollars to repair, is it worth it?
toyo47 is offline   Reply With Quote
Old 10-07-2007, 10:58 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
just mark the postion and do it yourself,, put an exact mark on the block... with paint (white) or scratch it there...
or spend the $125.00
retiredat44 is offline   Reply With Quote
Old 10-08-2007, 08:26 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
yeah.
Old 10-08-2007, 04:24 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
even if it came to you messing the timing up, it would still be cheaper to do it yourself and have someone do the timing for you after
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-08-2007, 06:05 PM   #5 (permalink)
View toyomoho's Photo Gallery
Which O-ring? If outside on the housing nothing will happen but leaking oil. Takes about an hour to change including retiming. If leaking on the distributor driveshaft oil can leak into the cap and result in ignition problems over time. This seal is more difficult to replace.
Old 10-08-2007, 06:08 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
You need a press to do the inner seal, because you need to press out the distributor pin.
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 07:53 PM
Need advice on fixing leaking power steering pump ganda1f 7th Generation (1993-1997) 9 10-05-2007 06:39 PM
Ring Gear ROBS Camry & Solara Lounge 17 05-07-2006 11:40 PM
A story about my school class ring... epinionator89 Off Topic 6 08-20-2005 07:20 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
