Cold start time switch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2007, 03:12 AM   #1 (permalink)
View KevD's Photo Gallery
I have a 91 corolla with the 4a-fe motor. I'm wondering where the cold start time switch is located.. Any way of testing it? Thanks!
KevD is offline   Reply With Quote
Old 10-09-2007, 08:24 PM   #2 (permalink)
Gameroom cash: $121755
it's in the coolant outlet on the side of the head, above the transmission
the csi itself is located in the middle of the manifold (top) and attached to the fuel rail
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 10-09-2007, 10:45 PM   #3 (permalink)
Ok, thanks. Would a faulty switch cause a hard cold start condition? Once it fires (after cranking for quite a while) it does rev at around 1500rpm until warmed up. I'm assuming this is due to the cold start injector.
Thanks for any info. I'd really like to get this sorted before winter as it's hard on the batt and starter! (And unforgiving when it's -45 celcius outside!)
OH, when it's plugged in, it fires up in a couple cranks... Thanks again!
Old 10-10-2007, 01:04 AM   #4 (permalink)
the csi switch is both a thermal switch and the csi system gets turned on once you turn the key to start the car (not to the ignition switched, but to the starter..... the 12V lead from the starter connects to both the csi and the switch)....
Old 09-16-2010, 09:34 PM   #5 (permalink)
View tiemen's Photo Gallery
cold start ejector switch
22RE efi would start cold, but failed to start when hot - problem was the switch stuck on "cold start" mode = flooding engine = no start
remove electric plug to the cold start ejector and wrrrrrroom - away you go- thanks to Mr Richer for sorting that one out in 15 minutes when 2 Toyota mechanics got nowhere in an hour - key to solving the problem was the 'wiring diagram' for starting your engine
tiemen is offline   Reply With Quote
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 12:54 PM
cold start injector won' fire...3vz-fe mcgowaw 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-01-2006 04:41 PM
EGR Time Delay Switch? chinesemechanic Supra Forum 5 07-10-2006 10:53 AM
1986 Camry Cold Start Problem toored 1st & 2nd Generation (1983–1986 & 1987-1991) 12 07-04-2006 09:59 AM
Cold Start Switch 86CRESSIDA86 General Discussion 7 01-07-2002 11:10 PM
