overheating while on highway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2007, 10:10 PM   #1 (permalink)
View toyo47's Photo Gallery
USA overheating while on highway
I started driving my 1990 toyota corolla on the highway and the check engine light came on, my coolent temp. gauge started to go up towards hot.
i drove off the highway and temp gauge returned to normal, check engine
light still on. the vehicle only overheats when driven on the highway.
what could be causing this problem?
toyo47 is offline   Reply With Quote
Old 10-11-2007, 11:22 PM   #2 (permalink)
View mopars&corollas's Photo Gallery
Have you verified at all that your gauge is working correctly? Did you check the water pump weep hole? That does seem a little strange, but I would start there if i were you.
mopars&corollas is offline   Reply With Quote
Old 10-12-2007, 12:02 AM   #3 (permalink)
7th Gen Apprentice
View costadragon220's Photo Gallery
^^ I agree then check the thermostat, gaskets etc are all good.
costadragon220 is offline   Reply With Quote
Old 10-12-2007, 10:33 PM   #4 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Water Pump
If I were you get that water pump change!
FinalGear is offline   Reply With Quote
Old 10-15-2007, 12:03 AM   #5 (permalink)
View gum_agile's Photo Gallery
had experienced this problem before, overheating on a highway... check the aux fan for the radiator, the bearing should be spoiled/too loose that when running on a highway with strong external wind it suddenly stalls/stopped which causes the overheating.
try rotating aux fan blade by hand, if it rotates easily, should have problem.
gum_agile is offline   Reply With Quote
Old 10-16-2007, 03:33 PM   #6 (permalink)
View darcsyde's Photo Gallery
the fan shouldn't kick on on the highway, check the radiator cap, make sure it's not loose, check thermostat, check fluid level, check for no leaks.
your car doesn't overheat when your off the freeway cuz your fan kicks on then
darcsyde is offline   Reply With Quote
Old 10-18-2007, 09:52 PM   #7 (permalink)
Volksrod's Avatar
View Volksrod's Photo Gallery
Check coolant level, then smell it, if it smells bitter you may have a head gasket leak.
Check for debris built up between AC condenser and radiator.
No fan is needed after 30mph.
Thermostat wax pellet may have leaked and no thermostat will no longer open fully.
If coolant is very old and acidic it may have eroded the blades right off the water pump and will no longer provide enough flow.
Check temperature across radiator face, any cold spots indicate a restriction.
Volksrod is offline   Reply With Quote
Old 10-18-2007, 11:12 PM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
what was the check engine code?
Old 10-19-2007, 10:29 AM   #9 (permalink)
View tashirosgt's Photo Gallery
Gum_agile's remarks bring up an interesting question. When driving on the highway, does the force of the incoming air rotate the fan blades (of a fan with good bearings) even when the fan is off?
tashirosgt is offline   Reply With Quote
Old 10-19-2007, 11:04 AM   #10 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
i vote thermostat...
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Interstate Highway Trivia Deuce Off Topic 2 10-05-2005 11:11 AM
$3.00Plus per gallon! I LOVE MY TACO! Man I am sooo glad I opted for the taco and not robsatx 2nd Generation (2005+) 34 09-15-2005 01:55 PM
car died on highway chadi Archived Corolla threads 14 09-13-2005 11:42 AM
UPDATE: HELP! diagnosing overheating problem!! stackz Camry & Solara Lounge 14 03-02-2005 01:22 AM
Please help newbe !!!!! 92 camry V6 overheating vinniekhosla 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-06-2004 04:27 AM
