performance carb - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2007, 04:13 AM   #1 (permalink)
View atxcorolla's Photo Gallery
Question performance carb
anyone know where i can get a performance carb for a 89 i can only seem to find one for an 88 which has all the exact same bs but isnt offered on the 89 anyone know if they will line up or not or if you know a company who offers a performance carb
atxcorolla is offline   Reply With Quote
Old 10-20-2007, 09:41 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
87 to 92 would have the same carb.
Flashmn is online now   Reply With Quote
Old 10-20-2007, 03:17 PM   #3 (permalink)
View EverAE's Photo Gallery
weber 32/36? just need a adapter plate, and need to adapt the throttle linkage a little too i believe.
EverAE is offline   Reply With Quote
Old 10-24-2007, 11:40 PM   #4 (permalink)
wheres a good place to get an adapter plate
Old 11-11-2007, 04:35 PM   #5 (permalink)
View LChineze's Photo Gallery
are weber carb kits smog legal in california? we have some strict emissions laws in california and a performance shop i go to a lot says that weber kits are not CARB legal cause they disconnect the vacuum lines and hoses. i searched for some reviews and a person who had it installed it on his truck said that performance gain was minimal (they advertise an 15-20% power gain) and it made his truck thirsty cause it was running too rich (even when they were changing the settings on the carb).
i drive an 1987 corolla sedan (AE82) with the 4ac engine with carb, so i was looking for some much needed additional power. i was contemplating the 4age 20v swap, but its kinda expensive for an old car with no available aftermarket suspension parts. anyone know good or bad things about weber carbs?
LChineze is offline   Reply With Quote
Old 11-11-2007, 05:21 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Depends on what weber, weber is a maker of carbs, not a specific carb.
DCOE's can be thirsty, but they do give good throttle response.
DGV can be close to stock, if not better.
Old 11-11-2007, 07:05 PM   #7 (permalink)
i've doing more research and the only thing that concerns me is whether the carbs will actually perform as advertised. the last thing i want to do is shell out $200-$300 for a carb that drinks fuel like soda, while most likely not be smog legal. the Weber 32/36 Carb is recommended if drivability and fuel economy is more important, while the 38mm DGAS carb is more performance oriented.
strangely enough, for some reason, paradise racing sells an aggressive carb, cams, valve springs package that will guarantee 40hp and power band up to 8,000 rpm. if the 38mm is best suited for performance, why do they use the 32/36 as the main carb piece?
Old 11-11-2007, 07:23 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Even the 32/36 will flow alot, the dual throat system will make it nicer to drive around town than a single bore/dual bore of the same size.
Never fiddled around with a 38DGAS.
Old 11-15-2007, 01:02 PM   #9 (permalink)
where did you find the kit at
Old 11-15-2007, 01:50 PM   #10 (permalink)
the kit is available at paradiseracing.com. look under "efi/fuel system: carburetors."
Toyota Corolla Carb Rebuild retiredat44 General Discussion 3 03-19-2006 05:36 AM
Performance Auto & Sound Magazine's Canadian Nopi Nationals Tour 2005 PAS Events Regional Meetings and Events 0 07-26-2005 01:17 AM
Is there a point to do performance modifications? persianKID Camry & Solara Lounge 5 04-28-2004 10:35 PM
Gen4 performance mods? (4cyl) icedmetal 3rd & 4th Generation (1992–1996 & 1997–2001) 22 11-14-2003 04:14 PM
01 & custom exhaust: performance gains ata3001 Archived Corolla threads 3 01-16-2003 09:44 PM
