1991 corolla dead PLEASE HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 08:26 PM   #1 (permalink)
View joshdsouza's Photo Gallery
I posted this thread cuz i couldnt figure out the problem on my 91 corolla. But yeah the other day i was driving up a ramp and noticed the engine starting to overheat and well it shut itself down. But now it wont start up again. Ive changed the starters and everything else seems fine but whenever i try and start the car the engine wont turn. Itll crank but thats all it does. Ive checked the fuel line. Any help would be greatly appreciated
joshdsouza is offline   Reply With Quote
Old 10-23-2007, 09:23 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Do you mean that you've changed the spark plugs? And how did you check the fuel line?
tashirosgt is offline   Reply With Quote
Old 10-23-2007, 10:10 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Question
it turns, but won't crank?? what does that mean?
Looks at plugs, see if there is any sigh of coolant, water. Check to see if camshaft is turning, in case the timing belt broke. Maybe a temp sensor triggered the ecu and that needs reset? (maybe not, but ya never know) Was it really over heating, or was there a coolant fan malfunction, which triggred the ECU to make it think it was overheating, broken, and a relay went bad?
need more info..
retiredat44 is offline   Reply With Quote
Old 10-27-2007, 10:34 PM   #4 (permalink)
Well initially there was oil that leaked into one of the sparkplugs. got it out. I should try n reset the ecu how do u do that by the way? but yeah man i really appreciate the help
Old 10-30-2007, 03:49 AM   #5 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
..............Ive changed the starters and everything else seems fine but whenever i try and start the car the engine wont turn. Itll crank but thats all it does. Ive checked the fuel line. Any help would be greatly appreciated
If the engine cranks and turns over but doesn't start then the starter is fine. I would pull out one of the spark plugs and check for a spark by holding thread end to ground. If you have spark and the fuel is fine you need to check for compression in the cylinders.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
Old 10-30-2007, 03:57 PM   #6 (permalink)
View 1991corolla's Photo Gallery
well, i'd say it sounds like the timing belt broke (happened to my sis when she was driving my parents '91 Corolla, which i am now driving...) the overheating leads me to believe that you may have done some damage to the motor internally... but hey, wtf do i kno... i'm only 16 (17 in less than a month ) and am only really good with old school muscle cars
1991corolla is offline   Reply With Quote
94 Corolla TOTALLY Dead ! wild4stangs Archived Corolla threads 6 08-08-2006 11:48 PM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 01:26 PM
1991 corolla gts tc_gts Vehicles 4 07-22-2005 09:19 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
Is 1991 Corolla ae92 Noninterference engine? jenniferimai Archived Corolla threads 6 10-04-2004 07:28 AM
