engine mis-firing during acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 10:33 AM   #1 (permalink)
View zturek's Photo Gallery
I have 89 toyota corolla with carb that misses during acceleration.
I seems to run ok when it is cold an the choke is on. It starts
having this problem during acceleration only but it does seem
to idle ok.
zturek is offline   Reply With Quote
Old 10-26-2007, 11:11 AM   #2 (permalink)
View mopars&corollas's Photo Gallery
That can be so many things. If you manually rev you engine, does it miss? First guess would be a vacuum leak. Have you checked plugs and wires to make sure they are good and that you have solid spark?
mopars&corollas is offline   Reply With Quote
Old 10-26-2007, 11:38 AM   #3 (permalink)
Yes it does miss when I manually rev the engine. The sparks plugs
and wires were replaced about two months ago along with the fuel
pump and filter which was having vapor lock issues.
Old 10-26-2007, 11:45 AM   #4 (permalink)
joeyicu's Avatar
View joeyicu's Photo Gallery
an engine under load has little to no vacum compared to idle with the throttle plates closed
since spark is not the issue, i would have to lean towards having gunk in your carb, id take it off and clean it out making sure to be careful not to break anything and also replace all the gasketry as you go even if its reusable, that may help
its the 1.6L motor with the little 1 barrel right?
-<2001 Chevrolet 2500HD 6.6L 5A 4x4>- 14.6@88mph - Edge Juice Chip, Cut Muffler
-<1990 Nissan 300zx NA 5M 2+0>-
Stillen Catback, Kenwood HU
joeyicu is offline   Reply With Quote
Old 10-26-2007, 12:06 PM   #5 (permalink)
Yes it is a 1 barrel carb. Before I go pulling carb of I would
like to make sure that is the problem. Is there any thing
that I can try to verify that it is the carb?
Old 10-26-2007, 12:15 PM   #6 (permalink)
And yet vacuum was the problem I had with that exact same issue. Notice I did preface the comment with saying it could be a lot of things. Definitely take a look at the carb and maybe use a little carb and choke cleaner on it before you pull it off the engine. If something isnt sealed that should be, it will cause this issue. I have also experienced this issue on a big engine with poor wiring.
Old 10-26-2007, 12:21 PM   #7 (permalink)
If you had any idea where your vacuum leak was- hold an unlit propane torch in the neighborhood. If your engine revs up, you have a vacuum leak.
Old 10-26-2007, 06:59 PM   #8 (permalink)
Gameroom cash: $128200
View 90 GP's Photo Gallery
Check your timing and the vacuum advance unit on the distributor. Check for leaks in the rubber vacuum lines that connect to the advance diaphram.
90 GP is offline   Reply With Quote
Old 10-26-2007, 08:08 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it could be the distributor, rings, headgasket, a crack, anything that can cause it to lose compression. Problems with the intake, a leak in it or such. Btw the 4af has a 2 barrel carb, not 1...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-26-2007, 10:59 PM   #10 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
I vote distributor,, you can go get a rebuilt with lifetime warranty... with core excahnge... I have been through this problem several times... it really turns the car into bucking bronco..
1989 Corolla SR5, carb, 5 speed manual,,
retiredat44 is offline   Reply With Quote
Old 10-27-2007, 08:34 AM   #11 (permalink)
joeyicu's Avatar
o ok i didnt know thats why i was asking, ive worked on that motor only a little bit in high school and i rember it being carberated, and i also rember dumping a couple gallons of water into the carb to clean the car up a little bit lol
it was a donated vehicle, it actually ran alot better after i circulated the h20 threw the system and smoked out the automotive courtyard
Old 10-27-2007, 10:28 AM   #12 (permalink)
View Awheet's Photo Gallery
Well me and my dad washed out my engine bay the other day and its been running gough and he couldnt figure out why. So he took off the spark-plug wires and there was water in one of the spark plug bays. It was missfiring during acceleration as-well. Now it doenst do it.
Awheet is offline   Reply With Quote
Old 10-27-2007, 03:06 PM   #13 (permalink)
joeyicu's Avatar
well there ya go my man
a tip i usually take my plug wires off completely and then when im done ill air out the plug holes with compressed air or something just to get the stuff outa the holes
Old 05-14-2008, 05:16 PM   #14 (permalink)
engine mis-firing during acceleration (reprise)
A many months I have finally been able to look at this problem again.
I tried the unlit propane torch but no vacuum leaks found.
I different thing that I noticed is that this only runs rough
when I am under acceleration (throttle about a 1/3 down).
I can not get this problem in park or trying to power brake
and accelerate.
I looked at the boots for the spark plug wires they are clean
no oil or moisture.
I can not quite tell if it is a mis-fire or fuel Carburetor
acceleration issue.
I am going to try it again tomorrow morning to see if
it is different under cold engine conditions.
Any other inputs will be appreciated.
Thanks for your help.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 06:07 PM
