1992 Corolla w/ rough idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2007, 12:08 PM   #1 (permalink)
View eggadeath's Photo Gallery
I bought this car off of a grandmther about 2 months ago. It only has 85k miles on it. It also runs perfect until I pull up to a light. After stopping at the light it runs fine for a few seconds and then starts to hesitate and wants to stall. If the car is not warmed up it will stall. I've also noticed a strong smell of gas coming from the car. I can really smell it when i go into the garage in the morning. Also seems to getting poor mileage.
I've replaced air filter, plugs, plug wires, dist. cap and button, also ran codes and no problems arose.
Any suggestions would be greatly appreciated.
eggadeath is offline   Reply With Quote
Old 10-30-2007, 10:04 AM   #2 (permalink)
View tashirosgt's Photo Gallery
I don't recognize those symptoms as defining a particular source of trouble. So, my suggestion is that you start with the simplest checks. Is the sensor that goes into the side of the box that holds the air filter plugged in? Is the PCV valve clogged?
If you can make the car run rough when it idles, use a timing light and check that you are getting spark on each wire when this happens. You can hold a length of pipe or stick against each injector and listen to see that it is firing. Also do a compression test. These would be checks for something that is causing combustion to fail.
tashirosgt is offline   Reply With Quote
Old 10-30-2007, 11:14 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
The fact that it "smells like gas" didn't trigger any flags that this could be fuel system related? check your fuel filter as it could be clogged, it could also be a failing fuel pump.
Old 10-30-2007, 06:34 PM   #4 (permalink)
Gameroom cash: $128200
View 90 GP's Photo Gallery
Check for fuel leaks in the gas lines under the hood and back to the gas tank.
90 GP is offline   Reply With Quote
Old 10-30-2007, 06:41 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Check for wet spots under the injectors. Those "O" rings and grommets get real brittle after a while and allow fuel leaks at the top of the injector and air leaks at the bottom.
Had the same problem with my '92.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 10-31-2007, 11:26 PM   #6 (permalink)
Thanks
I forgot to mention that I did replace the pcv valve. And yes of course I think its fuel system related. But was seeking a little advise before I tried every solution under the sun. Ill try the fuel filter. Ill do all the others as well and see what happens.
Thanks again.
Old 11-01-2007, 04:10 PM   #7 (permalink)
Donald's Avatar
In a case where you are smelling fuel, I would look for a leak first.
Old 11-01-2007, 05:12 PM   #8 (permalink)
I checked the injectors and they are functioning. I checked the plug wires with a timing gun and they are firing. There is no gas around the O-rings and no leaks visible when car is running or stopped.
Over all the car runs great except at stops. Seems to be starved for fuel when in drive at stop lights, symptom lightens up when I put the car in neutral. The over all problem gets better as the car warms up.
Old 11-22-2007, 05:36 PM   #9 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
that sounds more like the IAC valve on the intake just before the butterfly-valve there are two parts the top has a screw to adjust the idle you might want to bring it up some and the lower is supposed to have a diaphram that opens and closes, mine was frozen open so i filled it with thermo-silicon and put it back together(i only need the screw now) and it runs fine.
stuck open i was idling at 2000 so it is stuck shut it would stall!
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 06-25-2008, 10:58 AM   #10 (permalink)
View stagnot's Photo Gallery
did you ever find out what the problem was? i also have a problem like yours.
stagnot is offline   Reply With Quote
Old 06-25-2008, 11:19 AM   #11 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
you might smell gas because your gas cap is not sealing properly and I still think it's the toyota equivelent of the IAC valve in american cars...
i had a similar problem you can either get another Throttle body from a junker or you can take it off and unbolt the valve ass. and (don't recommend) i filled the sucker with RTV and that way your idle-adjustment screw and your timing are the only things affecting your idle... mine has not failed in a year since.
88' FJ 62 - My Baby
91' AE92 - DX - GTS
rough idle at dead stop 1996camry 3rd & 4th Generation (1992–1996 & 1997–2001) 9 06-30-2007 09:06 PM
Rough idle, failed emissions ??? fdeeznutz Pre-88 Toyota Pickup/Hilux 6 06-11-2007 03:56 PM
rough idle GuJu MaN 89 Archived Corolla threads 4 12-14-2005 05:14 PM
1992 Corolla DX with Rough Idling... Mirad2003 Archived Corolla threads 3 10-16-2005 02:05 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
