'92 revs, not moving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2007, 12:25 PM   #1 (permalink)
View scottt60514's Photo Gallery
I have a 92 prizm with a 3 speed auto. The problem started with a loud pop, but the car drove fine for about 10 miles. The next time it was started it wouldn't move, it just revved. Later I tried driving the car to my house and made about six miles before it revved with no movement. You could hear a whine that went up with revs while it was moving. I shut it down, let it sit for about 15 minutes and tried again. It drove for about a quarter mile before it wouldn't move again. It's been sitting for a few months and now has a whine that seems to rise with rpm's, but will drive fine for a short distance. Then the engine revs, but the car won't move. It acts like it's in neutral. Someone said it was the differential, but I'm looking for other opinions. Thanks
scottt60514 is offline   Reply With Quote
Old 10-30-2007, 12:48 PM   #2 (permalink)
Mini truckerrr
DietoRemain's Avatar
View DietoRemain's Photo Gallery
torque converter?
99 tacoma ext. cab SR5
K&N FIPK intake,DougThorley Headers,Gibson Exhaust
full air ride(BAGS!)
DietoRemain is offline   Reply With Quote
Old 10-30-2007, 01:00 PM   #3 (permalink)
I forgot to mention after a couple months of sitting it started leaking some fluid. I didn't realize it until it had already soaked into the concrete, so I couldn't tell for sure what it was. I checked the oil, brake fluid and ps fluid and they were full. I checked the trans. fluid with the engine off, and there was enough to be on the stick. I know you're supposed to check it running but I didn't want to damage anything if the fluid was low.
Old 10-30-2007, 01:19 PM   #4 (permalink)
View tashirosgt's Photo Gallery
Check your transmission fluid level.
Put the front end up on jackstands so the front wheels are off the ground. Put it in gear and see if the half-axles turn. If they turn at the differential-end and not at the wheel-end then you broke a CV joint.
With the car back down on the ground, check the fluid level in your differential.
tashirosgt is offline   Reply With Quote
Old 10-30-2007, 01:44 PM   #5 (permalink)
View 94_Rolla_Guy's Photo Gallery
you might want to check the differential fluid as its got a separate case for the differential fluid see whats in there
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-30-2007, 10:27 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
You didn't want to check it while running.. but you still drove it? that makes no sense.
Old 10-31-2007, 11:29 AM   #7 (permalink)
I wasn't the one driving recently. I injured my back so I can't do much of anything. I checked the fluid level a few days before the last time it was driven. I will have somebody check out the suggestions above. I have to rely on somebody else to do it right now, so it will probably be a few days before I find out anything. It gets very frustrating not being able to do simple things that should be so easy.
Revs stay high when shifting 4th to 5th Avery 2nd Generation (2005+) 74 04-04-2008 07:48 AM
'92 Paseo Revs High sometimes bojo09 Tercel, Paseo, Starlet, and Sera Forum 1 09-24-2007 07:24 AM
92 Camry Stereo Bracket Install Mania!!!! FarmerJ Audio, Video, and Security - Tech 3 03-28-2007 05:30 PM
Revs low when cold and high when warm MKII Gibby MR2 Forum 12 11-29-2006 11:08 AM
92 Celica GTS Plat Celica Forum 7 06-21-2004 10:07 PM
