Cold starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 07:57 PM   #1 (permalink)
View bhd125's Photo Gallery
Cold starting
I have a 1992 Corolla, when the engine is cold the engine will start and run for about 15 seconds and then starts to stumble, you turn the engine off and restart it and it will run fine. Once the engine is warm it will restart. No codes but have replaced the coolant temp. sensor, any ideas?
bhd125 is offline   Reply With Quote
Old 11-04-2007, 08:20 PM   #2 (permalink)
View wheredoesthisgo's Photo Gallery
How many miles. What do you know of the last service?
wheredoesthisgo is offline   Reply With Quote
Old 11-04-2007, 08:28 PM   #3 (permalink)
It has 202,000 miles with the routine maintenance.
Old 11-04-2007, 09:43 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
bad cold start injector or associated circuitry perhaps?
Old 11-04-2007, 09:53 PM   #5 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Hop Here!
Just hop to Autozone troubleshooting section on their website and narrow down the problem...
FinalGear is offline   Reply With Quote
Old 11-05-2007, 04:47 AM   #6 (permalink)
The TN Member
View punter's Photo Gallery
Sounds like a vaccume leak, check all the hoses on/from the intake for cracks or leaks.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-05-2007, 09:07 PM   #7 (permalink)
Bitter's Avatar
vac leak would cause a high idle
Old 11-06-2007, 11:52 AM   #8 (permalink)
How many ohm's should the cold start injector be?
Old 11-07-2007, 11:09 PM   #9 (permalink)
The TN Member
Depends how big a leak it is.
Old 11-07-2007, 11:58 PM   #10 (permalink)
Bitter's Avatar
maybe i have my gens mixed up, but the 6th gen was map based also or did it have an AFM? with an AFM unmetered air can cause stumbling/lean problems. on a map system an airleak behind the throttle will just cause a chronic high idle.
Old 11-09-2007, 05:45 AM   #11 (permalink)
The TN Member
Ah I assumed all the US spec ones were AFM, my bad.
Starting problem in the cold? crabjoe 5th & 6th Generation (2002-2006 & 2007-2011) 19 02-10-2007 04:05 PM
Starting Problems TRKKID 3rd & 4th Generation (1992–1996 & 1997–2001) 12 01-15-2007 09:56 AM
Very loud noise when starting cold PaulM Camry & Solara Lounge 4 06-17-2005 03:20 PM
Prius Cold Starting 98CamryLE Prius Forum 6 06-01-2005 12:11 AM
