Failed smog high NOX - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2008, 06:13 PM   #1 (permalink)
View ..damn..'s Photo Gallery
Ok my car passed everything but the NOX i am thinking egr valve or cat? what do you guy's think?
Also last night as i was driving back home my check engine light came on?
91 Coorolla dx 3sp
..damn.. is offline   Reply With Quote
Old 12-29-2008, 08:40 PM   #2 (permalink)
just a nobody
What is the code? Maybe it has something to do with the NOX problem.
N.E.O.
Old 12-30-2008, 12:59 AM   #3 (permalink)
N.E.O.
I can hook up an obd1 code reader?
Old 12-30-2008, 01:12 AM   #4 (permalink)
just a nobody
This is for a Camry, but you car has similar setup to check for codes, P23 to 27: http://www.camrystuff.com/manuals/Gen2/EFI.pdf.
N.E.O.
Old 12-30-2008, 02:06 PM   #5 (permalink)
Ok it's got a code 21...
You know how hard it was to find out what code 21 mean's!...lol I guess it's the O2 sensor.
Old 12-30-2008, 09:15 PM   #6 (permalink)
just a nobody
Code 21 is indeed for the oxygen sensor signal problem; however, it doesn't usually affect NOX emission though.
N.E.O.
Old 12-30-2008, 10:13 PM   #7 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
maybe he should check the whole exhaust line and the intake?
Rookie_One is offline   Reply With Quote
Old 12-30-2008, 11:42 PM   #8 (permalink)
View Duy-'s Photo Gallery
91 Coorolla dx 3sp
most likely egr valve unless your car uses a 3 way cat.
Duy- is offline   Reply With Quote
Old 12-31-2008, 12:02 AM   #9 (permalink)
just a nobody
Forgot to ask, what are your test results?
N.E.O.
Old 12-31-2008, 01:09 AM   #10 (permalink)
Ok installed new OEM o2 and the code went away..
Well my smog result's passed very very clean except the nox that failed. Now sometimes the car has a slight stumble at idle when warm im thinking it may be the egr?
Old 12-31-2008, 07:24 AM   #11 (permalink)
just a nobody
Have you check the timing?
N.E.O.
