1991 corolla front wheel bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2008, 04:11 PM   #1 (permalink)
View Sorcerer's Photo Gallery
When I purchased this corolla sedan 3spd auto 4AFE I drove it home with a seized brake caliper (about 20km's) which caused the rotor/caliper/hub to take some pretty serious heat... when I got it home I had a doner car and immediately started swapping parts.... The car has been great for 6 months, but I've the thought of a bad wheel bearing has been in the back of my mind the entire time due to the extreme heat the hub endured... The other day I noticed a bit of a growl at speed, and today I was checking the wheels for play and sure enough the driverside front has play (the one exposed to the heat) the rest all feel perfect, no play at all. I assume this means I need a new bearing... these are a pressed in bearing that requires a press to replace correct? Also can you repack and/or tighten these style bearing?
Also, anywhere anyones gotten a good cheap replacement would be great.. toyota's price is like 150 bucks just for the bearing....
thanks for any help and advice... has anyone done a write up on this at all? can you replace the bearings using a brass drift? bearing puller?
cheers
Eric
Sorcerer is offline   Reply With Quote
Old 12-30-2008, 05:02 PM   #2 (permalink)
View kcwa's Photo Gallery
You can get an axle bearing / hub assembly complete from Rockauto.com for about $140 ... or get the bearing along for about $30 to $50. Yes, the bearing would need to be pressed in if you get just the bearing.
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 12-30-2008, 05:16 PM   #3 (permalink)
thanks for the quick reply... anyone else?
I want to do it the cheapest/best way
Old 12-30-2008, 05:42 PM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
you could just go to a junkyard and get another hub... that would probably be the cheapest and fastest way.
'81 BMW R65
Old 12-30-2008, 06:03 PM   #5 (permalink)
View toyomoho's Photo Gallery
The bearing is pressed in. This requires a press, no way around it.
The autozone website has info on the job.
http://www.autozone.com/shopping/rep...00c1528006f5b5
Find out what bearing is used by visiting websites selling the bearing and listing the actual bearing number. Then do a web search on the part number. On occasion Ebay has bearings listed.
Old 12-30-2008, 07:29 PM   #6 (permalink)
..eage8 is right, the cheapest and easiest would be going to the junkyard. Check to find out what other cars are compatible like the Geo Prizm.
Old 01-03-2009, 07:57 PM   #7 (permalink)
View kileak's Photo Gallery
That bearing would be a reasonably priced part. You have to take it all apart anyway. To have it pressed in would cost very little. I wouldn't suggest to you to go try to find a whole new steering knuckle assembly.
I wish I had a GTS
kileak is offline   Reply With Quote
Old 01-06-2009, 03:16 PM   #8 (permalink)
What size is the nut in the center of the wheel?
Is this a good deal?
http://cgi.ebay.ca/88-02-Toyota-Coro...1227123001r660
looks like it would still need to be pressed in right?
