Oil pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2009, 08:50 PM   #1 (permalink)
View magoo_lc1's Photo Gallery
Oil pump?
I just found out today mine is starting to shoot craps. On a scale from 1-10 how difficult is this for a beginner to change? I know i have to change the timing belt too. This was told to me by my mechanic thats the issue. Its a low tapping sound down low on the motor. I have a second car so i just parked it tonight. I was thinking of attempting myself because the guy wants 400 bucks to do it and the parts 99.00
magoo_lc1 is offline   Reply With Quote
Old 01-02-2009, 08:50 PM   #2 (permalink)
Duh. I forgot to tell you about my car. Its a 91 dx fuel injected five speed 4afe.
Old 01-02-2009, 08:58 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I say difficulty would be 6 on a 1 - 10 scale, 10 being hard.
Yea, the timing belt has to be removed so it'll be best to change it. Same with the water pump and timing belt tensioner. The oil pan may have to come off as well.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-03-2009, 08:32 AM   #4 (permalink)
Thanks
Old 01-03-2009, 12:48 PM   #5 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
i helped my mechanic do my timing belt, water pump and seals and for some reason we didn't do the oil pump but he made the job look really easy.
it took about 30 min so i'd say whithout a lift by myself for the first time prob 2-3hours so including oil-pump i'd say closer to 4-5 hours... just because it's your first time.
(also i cant remember but i think we pulled pass. engine mount)
we pulled the alternator belt
water pump pulley
water pump
timing cover
tensioner
timing belt
*at this point you would see if you need to pull oil-pan i think you do...
then oil-pump.(don't forget to prime with petroleum jelly)
now the new oil pump goes back on followed by timing gear then
tensioner and new timing belt
water pump
timing cover 2&3
water pump pulley
alternator belt
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 01-03-2009, 12:49 PM   #6 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
does anybody have a preference for brand???
aisen is the direct manufacture replacement for like 80$
mellin or whatever it's called is supposed to be really good to but it's over 100$
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 01-03-2009, 04:19 PM   #7 (permalink)
I dont know what brand but its 99 and the local parts store.
Old 01-03-2009, 06:58 PM   #8 (permalink)
Gameroom cash: $134355
get an Aisin..... it's what Toyota will sell you.
you have to remove the oil pan to remove the oil pump..... my ae86 would be on the road if the pan didn't have to come off (the pickup tube bolts to the bottom of the oil pump, inside the pan).
Old 01-03-2009, 09:03 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
water pump pulley
water pump
timing cover
tensioner
timing belt
water pump
timing cover 2&3
water pump pulley
alternator belt
looks pretty good, but you have to take the valve cover off to get the top timing cover off, and you have to take the main pulley off to get the bottom cover off.
(and you should probably replace the valve cover gaskets)
other than that it looks good.
'81 BMW R65
Old 01-04-2009, 10:44 PM   #10 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
i never had to remove my valve-cover... in fact i've been meaning to change the gasket it's been sitting in my tool room for a month or two...
and yea removing the main pulley CAN work do it your way gosh... :P
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 01-04-2009, 10:46 PM   #11 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
oh and thanks i thought AISIN would be the way to go as that was what my moms oem pump from 88 was...
these parts sure do last the pump looks fine still!!!
any suggestions for water pumps??? i haven't found much for "name brand"
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 01-05-2009, 10:42 AM   #12 (permalink)
Rotary guy...
eage8's Avatar
I usually recommend rockauto for parts, they have a nice selection. They have aisin water pumps, but they don't come with the housing... which would probably be annoying.
'81 BMW R65
Old 01-13-2009, 11:55 AM   #13 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
thanks eage8 and this wed i DO plan to go to the junker AGAIN.... longest job ever!
88' FJ 62 - My Baby
91' AE92 - DX - GTS
