ok thats easy...
you follow the instructions on which freeze plug to take out, its heater specific as well as heater lead position. Then you remove that freeze plug, its easy if you have the tool to do it, not so easy if you dont. Then install the block heater to replace the plug and fill with coolant. Now a note, make sure the heater element is purged of air, most failures are caused by the heater element being fried due to an air bubble.
It not that hard if you have the tools and no theres no way to save the coolant.
