Loosing power? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2009, 11:30 AM   #1 (permalink)
View magoo_lc1's Photo Gallery
Loosing power?
I put a post up about my oil pump going out and was just wondering, Right when the pump started making noise, iwnt straight to my mechanic. The day before any of this the car felt like it was loosing power, like it would bog down in the low end but after about 2500 rpm or maybe a bit more(i dont have a tach) the car runs good. It almost feels like when your climbing a hill and your clutch is going bad. I am 38 and have never owned a auto trans car so i know what a clutch feels like when its going out..this is different. It will loose power badly going up any hills too. My mechanic said it could be fuel pump/filter related or just needs a tune up..i have not done one in about 40k miles. BTW I almost forgot the car is a 91 sedan dx with a 5 speed , fuel injected 4afe. Any suggestions?
magoo_lc1 is offline   Reply With Quote
Old 01-06-2009, 05:53 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I think if it was fuel starvation, it would be more pronounced at high RPM, not low.
I would start with the tune-up, and have them check the compression at the same time.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 01-06-2009, 09:31 PM   #3 (permalink)
Will do. I have a comp checker. Whats the range for a "healthy" 4af?
Old 01-06-2009, 10:47 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92
I think it's like 160 or 170 psi for minimum.
I don't think it's fuel starvation, I think it's too much fuel or too little air getting in the intake. Could be timing...
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-07-2009, 05:32 PM   #5 (permalink)
Donald's Avatar
Optimum is 191psi.
Minimum is 142.
Maximum difference between highest and lowest cylinders is 14 psi.
Old 01-07-2009, 08:44 PM   #6 (permalink)
Its odd, one day it was runnig great the next it feels like its bogging down.
