use sedan's corner lamps as blinkers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2009, 11:43 PM   #1 (permalink)
JDM fan
toyotaboyfreak's Avatar
View toyotaboyfreak's Photo Gallery
how can i do this? because the blinker on the bumper is useless cuz its in a stupid place where no one but the person infront of you can see.
1990 AE92 and 1990 ST184
http://www.cardomain.com/ride/3090702
toyotaboyfreak is offline   Reply With Quote
Old 01-06-2009, 01:51 AM   #2 (permalink)
View 92MX83's Photo Gallery
Actually, tbfreak, that's as good a location as any for the turn signals. If you were oncoming towards me, I'd like to know if you were planning on going straight or turning left in front of me. And if people are not responsible enough to use their turn signals and do a head-check before they merge/switch lanes, it really doesn't matter where they're placed.
If you wanted to use the corner lamps as turn signals, couldn't you just swap the wiring over, from the original turn signals in the bumper to the harness for the bulb in the corner lamp? Probably have to make it an amber bulb though, since the yellow reflector would only work for the sides.
Hmmm, wheels are turning now....
"Crush enemies, see them driven before you, and hear the lamentation of the women!" - Conan the Barbarian, on what is good in life
92MX83 is offline   Reply With Quote
Old 01-06-2009, 11:52 AM   #3 (permalink)
Slacker Extrordinaire.
View ae924d's Photo Gallery
i would like to do the same for mine, but, i would like for the corners to still act as the running lights yet 2nd as the blinker. while still using the original blinker. and once i install side markers i would like the side marker to do the same, both running light and blinker. if i can do that i will also do this to the rear side marker..
that's a total of 10 turn signals all together...sweet.
1994 Acura Integra RS (DC4)
1985 Toyota MR2 MKI-A
ae924d is offline   Reply With Quote
Old 01-06-2009, 05:32 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
You will need to find double fillament bulbs and sockets to fit into the corner lights.
Another option would be to just add a marker light to the side of the fender and wire it into the turn signal system.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 01-06-2009, 06:08 PM   #5 (permalink)
Gameroom cash: $134355
corolla-racing.com tech section long ago had a way (which it's setup in my car) having a standard single filament bulb in place and have the bumper/corner lamp alternate blinking when the blinker is on, and have the coner bulb on when the lights are on (as usual)...... might still be there.... you need one relay on each side and then the wiring directions should be up (if that site's still up, lol)
Old 01-06-2009, 06:24 PM   #6 (permalink)
Donald's Avatar
Yeah! I can see how that would work. Neat idea.
Old 01-06-2009, 09:14 PM   #7 (permalink)
JDM fan
haha dang, exactly what i was thinking about.
Old 01-06-2009, 09:22 PM   #8 (permalink)
JDM fan
kinda not sure if i understood so im just making sure lol. so when you use your blinkers and you have your corner lamps on, the corner lamps turns on and off like a blinker and when you turn your signal off they just stay lit? cause if that's what you're talking about then thats a great idea, can you give us the link? thanks
Old 01-07-2009, 02:27 PM   #9 (permalink)
hmm.... looks like that site is dead...... too bad to....
Old 01-07-2009, 02:55 PM   #10 (permalink)
View angralitux's Photo Gallery
My JDM corolla sedan came with corner lights that would work as binkers too. When I "upgraded" to the USA corolla corners, I lost that functionality maybe you already wired for it, just try with a JDM corner housing to see, I tried to figure out on my car how to do it, but gave up because of lack of time.
angralitux is offline   Reply With Quote
Old 01-07-2009, 08:01 PM   #11 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I had orange peanut bulbs in H4 headlamp housings, which I had wired by splicing the wires from the turn signals and into the peanut bulb connectors, I assume you could do the same with the corners, you could go to a junkyard and cut the wiring from another corolla and adapt it to yours... which is what I had done.
Old 01-07-2009, 09:39 PM   #12 (permalink)
JDM fan
did yur jdm corner lamps came with a double filament bulb?
Old 01-07-2009, 09:44 PM   #13 (permalink)
JDM fan
so im gonna tap into the connection of the blinkers?
Old 01-08-2009, 01:42 PM   #14 (permalink)
I'm not talking about modifying, just changing the corners to the ones that came off the JDM corolla. Like these:
I remember they would blink with other blinkers as well, but I changed to the US corners and I lost this function, I believe the wiring on the back of the corner case might play a rol on this, combined with a dual filament bulb, as this corner has a bump to allow a bigger bulb.
see the difference with US corner:
Old 01-08-2009, 04:42 PM   #15 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Ok, i figured out how you can wire it so that your corner will function normally but when the blinker is applied it will flash. If the running lights are on, it will alternate with the blinker and if your running lights are off then it will flash along with the blinker. It requires two relays and two diodes per corner of vehicle (unless you feel like running wire from the front to the back of the car for the rears). I'll share it with you guys once I figure out how to post up a circuit diagram.
SuperRA is offline   Reply With Quote
