91 corolla insutrument cluster swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2009, 04:15 PM   #1 (permalink)
View era167's Photo Gallery
Canada 91 corolla insutrument cluster swap
Hi Guy,
I own a corolla 91 (old huh) but I love this car. My instrument cluster is with no tachometer. Does anyone know if I got an instrument cluster with tach, would it be a plug & play and would work with my car especially the tachomter working without running a separate wire for it. Meaning, just swap it and everything works, or would there be some problem.
Thanks Guys,
era167 is offline   Reply With Quote
Old 01-17-2009, 04:52 PM   #2 (permalink)
Canada 91 corolla instrument cluster swap
Hi all,
Does anyone know if I replace my instrument cluster from a non-tach to a with tach be just a plug & play. Just slap the new cluster with tach and connect the existing harness and everything working including the tach. Has anyone done this already and did it work? Meaning everything working fine, without connecting a separate wire to the tach to work.
Thanks
Old 01-18-2009, 03:25 AM   #3 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
AE92
There's already a thread about tach conversions...
But the tach and tachless AE92 sedan instrument clusters are plug & play, no additional wiring needed. And swapping the mileage counter from cluster to cluster is simple as well, four screws.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-18-2009, 10:27 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Moved to the 6th gen Corolla section and both threads merged.
Old 01-18-2009, 11:12 AM   #5 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
plug an play
now do it
Rookie_One is offline   Reply With Quote
Old 01-18-2009, 11:14 AM   #6 (permalink)
Rookie_One's Avatar
correction : its simple as long as you dont drop the damn counter to the ground (luckily the one that i dropped by accident wasnt the one i wanted to use)
Old 01-18-2009, 12:30 PM   #7 (permalink)
SCT
iAzn
SCT's Avatar
AE92
Well, if you break the counter you want, hopefully the other one would still work. You might need to take a powerdrill or something to spin it up to your mileage, unless it's pass your actual mileage. Then you can just drive out the difference with your speedometer cable disconnected until you think it's about right and connect it back :P (i will kill myself if someone actually does that)
Old 01-18-2009, 02:20 PM   #8 (permalink)
Canada 91 instrument cluster swap
Thanks guy, going out now to scout for a cluster with tach at a wrecking yard. Will update you how it went.
Old 01-18-2009, 08:19 PM   #9 (permalink)
Old 01-18-2009, 08:21 PM   #10 (permalink)
thanks guys, just got back from the wrecker. Got a cluster with tach, slapped it in and everything is working including the tach.
Old 03-21-2009, 05:34 AM   #11 (permalink)
patcal's Avatar
View patcal's Photo Gallery
I am assuming this would work on my 90 DX as well?
Pat Callaghan
90 Corolla DX
Portland, OR.
patcal is offline   Reply With Quote
Old 03-21-2009, 06:17 AM   #12 (permalink)
AstroVannin's Avatar
View AstroVannin's Photo Gallery
For anyone interested ... Ive got an LE tach cluster and vaeiable int wiper switch available..
PM me
AstroVannin is offline   Reply With Quote
