Hey Guys.
I recently acquired a 1988 Toyota Sprinter SE Saloon with 150,043km on the odo (yes, 150,043km on a 21 year old car!)
All seems well except for a distinct lack of power under load.
Thought i'd try a couple of cheap fixes first; ran a bottle of
Wynn's Spitfire Injector Cleaner through the fuel system (recommended by a friend). This solved half of the problem. Then switched from 91 RON petrol to 95 RON - again, this helped somewhat but the basic problem remains.
Going uphill alongside cliffs, the echo sounds like the engine's pinking...or maybe missing a beat...so I:
- Checked the air filter - near new and thus spotless.
- Checked the spark plugs...again looked near new. As a precaution I cross-checked them against the ones recommended for my particular model and engine (5A-F; somewhat unusual as most Sprinters seem to be 5A-FE) and found that the ones in there are not the recommended model.
Spark plugs currently in there are NGK BCPR5ES
Recommended plugs are NGK BCP5ES
Both models are near identical except the recommended plugs have a .8mm gap (as opposed to .9mm) and are non-resistor (as opposed to resistor) which (finally) brings me to my question; would these subtle differences be enough to upset the electical system when under load?
Read lots of reports of things going wrong when non-resistor plugs are put in an engine designed for resistor, but nothing about the other way round...
Any & All thoughts appreciated
