91 corolla, runs but wont drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2009, 06:51 PM   #1 (permalink)
View nocturnalsst's Photo Gallery
Hey all, new to the forums.
I have a 91 corolla that will start and run fine, but wont drive.
It was driving fine then all the sudden wouldnt go into gear (5 speed). No grinding or anything when you put in gear, acts same as being left in the neutral position.
Any ideas?
nocturnalsst is offline   Reply With Quote
Old 01-23-2009, 06:52 PM   #2 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
check the linkage?
Rookie_One is offline   Reply With Quote
Old 01-23-2009, 07:07 PM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Does it actually go into gear? You should be able to feel it. Or is the shifter loose?
Does it feel the same shifting into gear with the clutch in and out? Or is it easier with the clutch in?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 01-24-2009, 05:27 AM   #4 (permalink)
I pulled part of the dash apart and can see the linkage moving from the inside. i still need to get a friend to help me check if its moving where it goes in the transmission.
I'll pay attention which way is easier without using clutch later on today
Old 01-24-2009, 11:12 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
does it not drive in any of the gears now? or just 5th? if it's any of the gears... you most likely have either a bad clutch or bad hydraulics (master and/or slave cylinder).
just fifth: it might be your linkage... or you just lost 5th gear on your transmission (doubtful)
'81 BMW R65
Old 01-24-2009, 02:30 PM   #6 (permalink)
Ok i fired her up and went through 1st 2nd and 3rd using the clutch then again without. The shifter goes into position much easier using the clutch. I spent a couple minutes toying with it.
Still no motion though.
Would this mean i can rule the linkage out?
whats the next step?
Old 01-24-2009, 03:28 PM   #7 (permalink)
View kcwa's Photo Gallery
Check the fluid level in the master cylinder...if it is low and more then check to see if you can shift and move. If the fluid is low you might have a leak that is getting air into the system. Might be time to replace the master and release cylinders. I have my replacement parts and gonna do that when I do the clutch...and it is a little warmer outside.
1990 Corolla SR5 Coupe 4AFE 5-speed
"Gentlemen, you can't fight in here! This is the War Room!"
~ Dr. Strangelove, 1964
kcwa is offline   Reply With Quote
Old 01-24-2009, 03:34 PM   #8 (permalink)
Also, how can i test master/slave cylinders?
Old 01-24-2009, 06:12 PM   #9 (permalink)
Rotary guy...
eage8's Avatar
if you can put it into gear and it still doesn't move, then your clutch is gone... It'll only be the master/slave cylinders if you couldn't put it into gear.
you can test the cylinders by having someone push the clutch while you look in the engine bay and see how far the slave cylinder pushes the clutch fork.
'81 BMW R65
Old 01-24-2009, 06:43 PM   #10 (permalink)
man that really sucks the tranny is under 2 years old.
Old 01-24-2009, 08:48 PM   #11 (permalink)
Rotary guy...
eage8's Avatar
the clutch isn't part of the tranny... did you replace it when you replaced the transmission?
'81 BMW R65
Old 01-25-2009, 05:18 PM   #12 (permalink)
alright looks like im replacing the clutch this week. probably tuesday or thursday.
is it normal for the clutch to randomly give out without sign? no slipping or anything, no symptoms
Old 01-29-2009, 04:41 PM   #13 (permalink)
Advanced auto brought up 2 different clutch models. Before june and after june. How can i figure out which half of the year my car is?
Old 01-29-2009, 05:12 PM   #14 (permalink)
nevermind, found build date
Old 01-29-2009, 05:59 PM   #15 (permalink)
Gameroom cash: $134355
nope..... the syncro's broke..... did the same thing in my ae92 like 5 years ago... I had no first or 2nd, but 3rd, 4th, 5th, and reverse worked......
you'll need a new trans
