MAF to MAP +20hp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2009, 10:47 AM   #1 (permalink)
View Gerkn's Photo Gallery
Japan MAF to MAP +20hp?
I have an '89 GTS and I read somewhere that the JDM 4AGE had a MAP sensor instead of a MAF sensor and it made a 20hp difference because of airflow restrictions. Is this true? Is there a way to just install a MAP sensor and take out the MAF? Would I need a JDM ECU to do that? How hard would that be? I'm a n00b, but thanks in advance.
Also - could I just fix the problem by installing a cheap air filter?
Gerkn is offline   Reply With Quote
Old 02-11-2009, 11:28 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
Is this true? No
Is there a way to just install a MAP sensor and take out the MAF? yes, but it's more trouble than it's worth
Would I need a JDM ECU to do that? yes, + the wiring harness and maybe a few other things
How hard would that be? pretty hard
could I just fix the problem by installing a cheap air filter? there's not a problem to begin with, but yeah, air filters help performance, but I wouldn't get a cheapo one.
'81 BMW R65
Old 02-11-2009, 03:19 PM   #3 (permalink)
Gameroom cash: $134355
there's about an 8-10 crank HP difference.... only way to tell is that the JDM smallports having identical engiens have about a 10 hp difference.
it's not simple. You would need the entire harness and ecu, or go full standalone and tune it.
Old 02-11-2009, 03:34 PM   #4 (permalink)
Question
So the USDM 4AGE and JDM 4AGE are the same except that the JDM has a MAP sensor and USDM has a MAF sensor and because of the different sensors, the JDM version gets +8-10hp at the crank? The engines are about the same otherwise?
I'm trying to restore the car to JDM-spec with maybe a few bolt-ons but I want to know if the JDM engine (which from what I read has 130hp as opposed to 112hp) is a lot better?
The use of an air flow meter (MAF) sensor, which restricted air flow slightly but produced cleaner emissions that conformed to the U.S. regulations, limited the power to 112 hp (84 kW) whereas the Japanese model — which used a manifold absolute pressure (MAP) sensor — produced 130 hp (97 kW). - Wikipedia on "Toyota A Engine"
Old 02-11-2009, 04:21 PM   #5 (permalink)
Rotary guy...
eage8's Avatar
if you really want to be "JDM" I wouldn't bother with that engine and just get a japanese 4A-GZE, it came in the japanese trueno GTZs and has a lot more power. (it's supercharged)
'81 BMW R65
Old 02-11-2009, 06:11 PM   #6 (permalink)
well you have to keep in mind that in 1989 your car came with a bigport. I am referencing a smallport 4age.... US/afm electronics it was rated at 130hp and the JDM/map electronics it was rated at 140hp. The motors themselves are identical.
the bigports also did come map and I am unsure on the power variances between them, as it's never really mentioned.
4agze's came in many car's.... aw11's in the US, AW11's in japan (same setup as in the US), and in ae92's and ae101's.
Old 02-11-2009, 07:17 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I thought the Japanese motors were also missing alot of the emissions equipment.. I don't remember seeing much of that stuff on Recardo's imported Levin when he popped the hood
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 02-11-2009, 07:36 PM   #8 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
X2, i they were late in adopting catalytic converter if i remember well
Rookie_One is offline   Reply With Quote
Old 02-11-2009, 11:58 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
not just the cat, things like the egr valve are missing too from what I remember
That was why our sr5's didn't have the 1.5 liter. Ours have 1.6 liter for the lower end models since the emissions equipment takes power from the engine.
Old 02-12-2009, 10:18 AM   #10 (permalink)
there is no EGR valve and the other sensors don't affect performance....
the EGR is closed at WOT, so the power figures wouldn't change with or without the EGR.
Old 02-12-2009, 11:18 AM   #11 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
and lots of corollas came with and without EGR. i have three ae92's and only the older 4af had EGR. heck i don't even run pcv but thats' unrelated...
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
