Random problems with 91 Corolla
Just bought a 1991 Corolla DX sedan, 57,000 miles, automatic transmission. It has four separate issues that keep cropping up, that hopefully you guys might be able to provide some input on.
1: Hard starting after sitting. It needs a couple cranks usually, and you have to gas it. If you've just driven the car, it's fine.
2: Smoky exhaust. I see smoke when basically no other cars are smoking. It is light in color, almost white.
(Given these two, I almost want to say the dreaded 'H' word, but god knows I DO NOT want to have to replace the head gasket on a car I just bought, so if there's anything else that could cause this ...)
3: When you stop at an intersection with the car in drive and hold it with the brake it seems to run kind of rough and shake a little bit. This is ONLY in drive, if you put it in neutral it's fine.
4: The transmission will occasionally lock into park. Push the shift lock override, and you can shift fine, but it's still annoying and it really shouldn't do that.
Any input would be very much appreciated. Thanks!
