HELP!! Do all ecu's interchange on 6th gens? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2009, 09:22 PM   #1 (permalink)
View dsm-drvr's Photo Gallery
Well, I thought I screwed up the Map sensor in my car... but turns out the ecu fried. I really need to know what years I can interchange the ecu into my 92 corolla or if it even matters. I got to go to the junk yard tomorrow, so if somebody can help me that would be awesome!
Thanks
dsm-drvr is offline   Reply With Quote
Old 02-17-2009, 12:40 PM   #2 (permalink)
Blof-fan's Avatar
Gameroom cash: $294750
View Blof-fan's Photo Gallery
No, different engine means different ECU. And even with the same engine type there can be some slight differences over the years. Best is to find a car from the same year with the same engine
It would help if we know what engine you are running
And now you know that MAP sensors are to be left alone
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
Old 02-17-2009, 01:27 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
Thanks
there should be a number on the ECU, I would just double check that that number is the same and you'll be good.
'81 BMW R65
Old 02-17-2009, 02:30 PM   #4 (permalink)
Gameroom cash: $134355
you'll have to find one specifically for a 90-91 4afe.....
88-89 4afe's had their own thing going on.... 88-89 4af's had no efi.... 90-91 match, but 92 is the odd year... Japan changed their corollas in 1992 but the body didn't in the US (hence why there is no 1992 ae92 gts but there are 1992 ae92's).... however, I'm sure the electrical did change in them here and there, and I would assume the ecu is one of the changes.
Old 02-18-2009, 08:52 PM   #5 (permalink)
Doobs
View WagonLover's Photo Gallery
Ecu
The year doesn't matter so much it is the model number on the take inside the back edge of the driver's door or posted on the door jamb. It should be AE92LG- DWK975 (made up numbers) - but you'll want to match those of your car to the one you are pulling the ecu from. Each model is different based upon transmission type, emission type (CA or Fed) etc. It should be easy enough to find one for around $30
WagonLover is offline   Reply With Quote
Old 02-19-2009, 12:20 AM   #6 (permalink)
this should be simple to find.... open the hood and look at the catalyst sticker.... CA or Fed.... or just look to see if the 4afe under the hood has an egr system.....
that being said, year does matter as the 88-89's have different electronics..... but good try.
Old 02-19-2009, 10:25 AM   #7 (permalink)
Doobs
All Year's are not created equal
I'll stick with what I said - it is not dependent upon model year - while '88 was the first year of production you probably do have some differences in electronic components from the '89, but if you get the model number off the door - mine is AE92L-AWMDKA - you are going to have the same components. I've got a '91 Wagon, made in Japan, but for parts like an ignition wire set it is what all the '92's have. Production date in a model year makes a difference. US made cars (by New United Manufacturing) have a totally different vin, but the model no. can still be the same. What I found is that by matching that 11 digit number, all the components, emissions (CA) and configuration (5 spd) were the same.
Old 02-19-2009, 02:17 PM   #8 (permalink)
I'm going to guess you haven't been to many junkyards and/or looked at the sticker that they started using in 1990 and later on these cars...... the information 1/2 the time is missing.
Best bet is to go off of the number on the ECU.... however, if you have a 90 or a 91... an 88 or 89 ecu won't work. And by 90-91 I mean catalyst year of 90-91.....
Old 12-11-2010, 05:51 PM   #9 (permalink)
View scruples's Photo Gallery
1991 ecu change
Hey i was wondering what your results were on the ecu swap. im changing mine out, got the # on the ecu 89661-12497. everyone ive talked too said match that number and you should be fine, ive bought one that came out of a prizm, but the #'s match, waiting for it to get here.
scruples is offline   Reply With Quote
Old 12-11-2010, 07:26 PM   #10 (permalink)
Rotary guy...
eage8's Avatar
if the number matches, you're fine.
'81 BMW R65
