CV shaft R&R ??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2009, 02:09 PM   #1 (permalink)
GIBEYERSON's Avatar
View GIBEYERSON's Photo Gallery
CV shaft R&R ???
They are disconnected on the outboard ends. I have tugged on them but they haven't popped out of the transmission. Do I need to pull harder or crawl under the car and undo something?
Thanks in advance.
GIBEYERSON is offline   Reply With Quote
Old 02-18-2009, 02:31 PM   #2 (permalink)
Gameroom cash: $134355
they are only held in place by a c-clip... sometimes that clip can get tweaked and the axle doesn't want to come off.... you can generally use a long prybar and pry the axle out... however if you do it against the seal you'll need to replace the seal.
Old 02-18-2009, 03:04 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
one of mine was ridiculously hard to get out, I used a ginourmous flat head screwdriver and about 2 hours, but a prybar would work better.
'81 BMW R65
Old 02-18-2009, 03:16 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
When the spider gear inside my auto tranny went, I didn't know it was that causing drag and metallic noises and clunks. It was either the tran or the axles, as far as I knew. The left CV was a bitch and wouldn't come out whatsoever, prying and all from all sides, smashing it and forcing it like rough sex. It never gave. I gave up and took the auto out and now it's a stick. I opened the diff cover afterwards and had to pry it out from the inside. Oddly enough, the axle was fine! The C-clip was just doing its' job so the axle the don't fly into someones eye when I crash.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-20-2009, 12:38 AM   #5 (permalink)
GIBEYERSON's Avatar
Thanx
I went back and put an edit in but I must have clicked the wrong button
I'm restoring a one owner 88 fx with 114K and it has been parked since 03.
Yeah I forgot about those c clips. It has been a while since I worked on a fwd system. The drivers side pried out easy enough, but the passenger side had limited access. I used a long bar to poke it from the back side. Both came out easier than you would think.
I was glad I had a drip pan handy!!!
Old 02-20-2009, 09:44 AM   #6 (permalink)
there's a 24mm bolt at the bottom of the trans (facing the drivers side wheel) that you should pull... it's the drain bolt for the trans.
Old 02-20-2009, 06:09 PM   #7 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
even after draining i still would have made a mess.. i don't think the diff drains very well on the c-52's
change often!
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 02-20-2009, 08:30 PM   #8 (permalink)
GIBEYERSON's Avatar
5 Speed fluid service
Yeah I noticed the drain plug while it was dripping. Any reccomendations on gearbox fluid type and quantity? I was lucky to find the owners manual in the glovebox but haven't read it yet.
Old 02-21-2009, 06:52 AM   #9 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I was doing the driver side ball joint and my axel fell out. I just about cried thinking I messed up my car because I didn't have the money to fix anything that expensive. A quick look at it and I was like wonder if it just slides back in, Viola fixed car
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 02-21-2009, 01:25 PM   #10 (permalink)
about 2.5 quarts of 80/90w
Old 02-21-2009, 07:44 PM   #11 (permalink)
GIBEYERSON's Avatar
Good to know
Sometimes you hear people highly recommend other additives or special blends.
Old 02-21-2009, 07:45 PM   #12 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
it calls for 2.9 but i always use 3. and 30 weight should be fine..
if you want something more substantial i use redline shockproof, mt-90, and royal purple synchromax 1 quart of each
though next time i will probably use 2qts mt-90 and 1qt. heavy duty shock-proof just for the load im giving it!!!
88' FJ 62 - My Baby
91' AE92 - DX - GTS
