4a flywheel photos (6 and 8 bolt, 200 and 212)
I don't have a 212mm 6 bolt flywheel but they look the same as a 4afe 200 but has the clutch surface that looks like the 8 bolt flywheel....
These 2 are both 200's:
notice that on the 8 bolt (4age) that there is a noticeable size difference... whereas if you look at the first photo the 212mm 8 bolt and 200mm 6 bolt have the same physical size
thought I would throw these up as I had a 200 out of the car for a short period.... (the others were just lying around)
