Broken Shock? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2009, 09:17 PM   #1 (permalink)
View kevin7782's Photo Gallery
Broken Shock?
I have 1992 corolla and recently the driver side rear shock bangs really hard every time I hit a bump. It seems to be worse when its cold out. So I wonder if there is some kind of fluid in there that is freezing. Maybe it was from hitting a pothole but it doesnt seem to be as bad when its warmer out. Does anyone know how to fix this? Thanks
kevin7782 is offline   Reply With Quote
Old 02-20-2009, 10:11 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
Change all your struts and strut mounts, or at least two in the rear, to keep all control even.
If there is fluid in a shock or strut, it wouldn't freeze. Likely you have a gas strut that is worn out. So instead of absorbing shock, it allows it to travel all the way and maxes itself result in a bang. Temperature differences can affect pressurized gas in a can.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-27-2009, 10:50 PM   #3 (permalink)
View 2fast0gsxr07's Photo Gallery
My car does the same thing. I thought the same idea, it was either broken or fluid was freezing. Its been a year and the car is smooth as hell in warmer weather and bangs in cold weather. I've just left it and its been annoying but fine.
2fast0gsxr07 is offline   Reply With Quote
Old 02-27-2009, 11:02 PM   #4 (permalink)
View toyomoho's Photo Gallery
Have someone drive the car over potholes while you listen to the drivers side rear upper deck area in the back seat. This is the area of the rear strut mounts. If the noise is from this area it could be a strut mount.
If not check the drivers side sway bar bushing and sway bar end link.
Old 02-28-2009, 01:19 AM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Try just pushing down on that corner of the car vigorously. If you can reproduce the noise that way, you should be able to figure out exactly where it's coming from.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 02-28-2009, 02:31 AM   #6 (permalink)
View ericdude's Photo Gallery
+1
Mine does this in front. Someday I'll buy the clamshell spring compressors and replace
the shocks so my towers stop getting the hell beaten out of them.
ericdude is offline   Reply With Quote
Old 02-28-2009, 07:51 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
push down on the cars corners, the blown shock will make that corner bounce more, Start at the front and make sure the car has been sitting for awhile before you do it, my bad shock builds pressure back up so it gets harder as you drive it.
or it could also be the plate on top on the front McPherson struts. When the bearing in mine went it made a loud banging noise. Pull them out and check the top by wiggling it. There should be no play in them. Mine has very little but it was enough to make the car very hard to control.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
