4AF (carburated) Hesitation when Accelerator Stomped - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2009, 03:54 AM   #1 (permalink)
View ericdude's Photo Gallery
No problem with acceleration or hesitation, unless I stomp the accelerator
down (usually in an amergency situation) when the vehicle is idling.
Then I get about a second of nothing before the engine does anything.
Pretty sure accelerator pump is working because if I don't give the engine a
pump or two after it's been sitting parked for several days, it won't start.
(I.e., I stomp the pedal before starting the engine, something that would
have no effect on a fuel injected vehicle.) Maybe it's pumping too much fuel?
ericdude is offline   Reply With Quote
Old 02-26-2009, 10:01 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
is it automatic?
otherwise I don't really see how that's possible...
'81 BMW R65
Old 02-26-2009, 11:29 AM   #3 (permalink)
Originally Posted by eage8 View Post
is it automatic?
Yes, A131L (3-speed auto). Problem happens with vehicle
idling in "drive".
Old 02-26-2009, 11:42 AM   #4 (permalink)
Rotary guy...
eage8's Avatar
idling in "drive".
sounds like a transmission problem. when was the last time the transmission fluid was changed?
'81 BMW R65
Old 02-26-2009, 01:03 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Does it sound funny when it does it? Like it is misfiring? because I get a similar problem. I have been trying to figure out what it is and at this point I am thinking spark plugs, cap and wires, fuel pump, the vacuum advance, or a combination of a couple of those things.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 02-26-2009, 02:21 PM   #6 (permalink)
I don't see how it could possibly be a transmission problem. The engine
was idling during the problem period. The transmission didn't do anything
wrong. I.e., I stomp the accelerator and the engine idles/stumbles for
a second before reving up.
I could remove the transmission and still reproduce the problem.
Possibly, my attention is usually on the semi or train that's roaring toward
me, the threat of which caused me to stomp the accelerator in the first place.
I'll have to check for that in a safe area to see whether you're right.
Looks like you haven't isolated it either.
I recently put in new NGK resistor plugs gapped to 0.043 so I don't think it's the plugs.
Old 02-26-2009, 04:58 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
yeah but we may also have 2 different problems, mine doesn't happen at idle. But sometimes pops up with the pedal not to the floor, or around 6000 rpm just seems to start missing like crazy and I have no power. I did the carb gaskets, so it wasn't them. Fuel pump seems to be supplying enough fuel. So I am thinking the vacuum advance in particular for my situation.
Old 02-26-2009, 07:45 PM   #8 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316600
View SCT's Photo Gallery
Adjust fuel/air trim and/or idle, it may be slightly rich/ too high. Or it may be off timing a bit. I use to have that problem.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 02-26-2009, 11:28 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
you can't adjust the air/fuel mix without drilling out the plug, wouldn't suggest it for anyone who isn't really good with power tools, go to far and you will drill into the screw!
Old 04-24-2009, 07:09 AM   #10 (permalink)
View Xen2050's Photo Gallery
I think I've seen this in other cars, my 4A-F with the same 3 speed does about the same thing, and 2 late 80's Camry's (4 cylinders). I even think airplane engines (4 cyl boxers) will do it too, if you hit the throttle too fast it kind of "floods" the engine with more fuel than it can burn for the rpm's? That's maybe a 1/2 second or so of the bogging no-go, then it spins up. If it's a lot longer then something does sound wrong.
Try smoother stomping, and look carefully for trains & trucks before pulling out If it's anything fixable, I'd want to try it out on mine, (as long as it's cheap & easy, I almost never notice the hesitation)
Xen2050 is offline   Reply With Quote
