A131L Interchangability - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2009, 08:21 PM   #1 (permalink)
View macst19's Photo Gallery
Does anyone know if an A131L (3spd 15 pan bolt) from a later model corolla would fit the AE92? For example, I found one for 200$ from a wrecked car with 73K but the car is an 01 Corolla. I read that from 84-02, Corollas used the A131L and this one I looked at was an A131L. I just don't know if things were changed that I might need to be aware of?
macst19 is offline   Reply With Quote
Old 02-27-2009, 02:17 AM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
There's a high possibility that the later models are electronically controlled while the earlier ones are not. I made this mistake with a later model 4 speed.
SuperRA is offline   Reply With Quote
Old 02-27-2009, 05:00 AM   #3 (permalink)
View ericdude's Photo Gallery
I don't think they would change a transmission from hydromechanically controlled to
electronically controlled without changing the model name (A131L). According to Wikipedia,
the A131L was used in corollas from 1984-2002 (three speed trannies). Therefore, I would guess
that a donor 2001 corolla would be compatible if it's a 3-speed.
ericdude is offline   Reply With Quote
Old 02-27-2009, 06:59 AM   #4 (permalink)
It's not electronically controlled because if I remember right an E at the end of transmission Model means electronically controlled. There is no A131E, just A131L.
Old 02-27-2009, 07:55 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
why wouldn't you upgrade to the 4 speed if you're replacing it anyway?
'81 BMW R65
Old 02-27-2009, 01:28 PM   #6 (permalink)
That's what I originally intended. However, find a 4spd is alot harder than finding a 3spd since after 1992, the 4spd went electronically controlled. The 93+ Corollas have the A245E. The 88-92 A240E is harder to find, and when I do find it, it's alot more than a A131L.
I just wanted to make sure that even if the A131L was still the same transmission that a few things hadn't changed but I guess it will be ok?
Old 02-27-2009, 01:33 PM   #7 (permalink)
Rotary guy...
eage8's Avatar
it seems fishy to me... the 98-02 corollas have 1ZZ engines. I'm pretty sure that the the bell housing would be different. you might be able to swap bell housings with your old one though...
'81 BMW R65
Old 10-23-2010, 01:22 AM   #8 (permalink)
View heavy47's Photo Gallery
Did you ever find out if the new a131l will swap into the older Corolla? I need to swap mine but only newer ones are available.
heavy47 is offline   Reply With Quote
Old 10-26-2010, 12:01 PM   #9 (permalink)
View cmgarst's Photo Gallery
Gen6 A131L Auto 3spd Question
I am also looking for an A131L 3spd Automatic - for my 1992 DX Coupe (4A-FE)
Need to know also if later year models up to 2001 with A131 would work in a 1992 ???
Sunday I was driving it around 60mph, and all of a sudden, a big wining sound then BAM! BAM! BAM! ....the transfer case / differential came apart inside, felt like I slammed on the brakes.
I've heard if this happens I need a new transmission, it's too hard / expensive to repair the transfer / axle gears?
cmgarst is offline   Reply With Quote
Old 10-27-2010, 08:59 PM   #10 (permalink)
Same here.... 91 Corolla DX Sedan. I need to know if a newer model A131L will work on it. Please help... anyone?
