89 Corolla idle issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2009, 10:33 AM   #1 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
Exclamation 89 Corolla idle issues
It has the carbed engine, 4AF? There is a bad dieseling problem, due to fast idling. Is there any reason I shouldn't assume that adjusting the idle screw will solve the problem?
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is online now   Reply With Quote
Old 03-06-2009, 06:24 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check to make sure that the choke is opening all the way when warmed up, If it is binding clean linkage /butterfly valve with carb cleaner. Another problem is the throttle positioner on the carb which is a dual vac unit . If you get a hole in either attaching vac line you can get the advanced idle speed. The throttle positioner is on left side of carb when facing front of the engine.Check the other vac lines for possible leaks as well.
90 GP is offline   Reply With Quote
Old 03-09-2009, 11:21 AM   #3 (permalink)
79Corona's Avatar
Is that the left side facing the front of the carb (float bowl glass)? Remember it's a transverse engine.
Bryan
86 Hilux LE longbed
Old 03-09-2009, 02:57 PM   #4 (permalink)
The throttle positioner is on the same side as the float bowl sight glass.
Old 03-09-2009, 03:01 PM   #5 (permalink)
Here is a link on how to check out throttle positioner.
http://www.autozone.com/addVehicleId...00c1528006f1cc
Old 03-09-2009, 08:11 PM   #6 (permalink)
79Corona's Avatar
Thanks, I probably have to take the air cleaner off so I can see everything. My daughter had to get back to school so I didn't have time to really look at it. I know the idle adjustment screw was not really working properly.
Bryan
86 Hilux LE longbed
Old 03-10-2009, 08:11 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I would check the timing also, just to be sure.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
