Shift Cable Snapped? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2009, 02:42 PM   #1 (permalink)
View macst19's Photo Gallery
CAR: 1992 Corolla
So today when I got home from school, I jacked up my car and I was going to adjust the shift cable. I followed the instructions in my Chiltons book. Whenever I moved the lever as far as I could right, it barely moved. Chiltons said to move the swivel two levers back but the lever never really moved much. I kept on with the instructions and it seems like the lever doesn't go down fully as it should? Is this a sign of a snapped cable?
macst19 is offline   Reply With Quote
Old 03-07-2009, 12:03 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Does it still shift into gear? I don't understand your thread... were you trying to adjust it at home and you snapped it or you think it snapped before you were trying to adjust it.
Old 03-07-2009, 07:30 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
Detach shift cable from tranny and move the lever. Can it move?
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 03-07-2009, 11:09 PM   #4 (permalink)
It shifts into gear. I was trying to adjust it because I thought it might have been out of adjustment, maybe stretched, or partially snapped. For R, I get nothing. Car doesn't move, reverse lights come on. For N, the car acts like if its in a first. For D, the car takes all 3 gears, and 1,2 work fine too. It's just that whenever I had to move the cable to the right at first and then move it over two levers, it didn't move. It felt like the cable wasn't long enough or something.
Old 03-07-2009, 11:11 PM   #5 (permalink)
If you're saying that I disconnect the cable from the lever, I did. The lever will move all the way to the right and back to the middle, no where to the left though, idk if that makes a difference.
Old 03-09-2009, 07:00 PM   #6 (permalink)
If this helps, whenever my car is in park, the shift cable does not look like this Furthermore, when the car is in neutral, the shift cable is not in the middle of the switch, rather it is a little past 3/4s. Whenever the car is in park, the shift cable is at the neutral base line.
