ae92 4agte build New Zealand - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2009, 06:25 PM   #1 (permalink)
View gasman's Photo Gallery
hi all, ive been on the forums for a while now but havent posted much in the last few years. i though ill post up my build for you guys (copied it mostly from another forum which i post regularly on)
heres my soon to be finished (hopefully) 4agte ae92 fxgt
or originally going to be a ae92 sedan but a learner driver with out a supervisor, wof, reg or insurance that decided to not give way made sure that did happen.
specs:
blacktop 4age block
4agze 8.9:1 oversized pistons and rods
550cc 3sgte injectors
action dan manifold
bazda supplied turbo
tial 38mm wastegate
tial copy 50mm bov (will get original when i get some more $$)
Link LEM G3 ecu
3" stainless exhaust
2.5" stainless IC piping
600x280x76 DSR intercooler
E58 gearbox with some sort of mechanical LSD
old engine
semi clean engine bay (20 years of road dirt and grime to clean)
shot of the mess ive made in the once clean and organized garage
head and rods waiting to be picked up to get built
engine back from being built by camb01 (thanks cam)
gearbox getting some new synchro (thanks warrick for sorting them out for me)
dirty corroded gearbox
after cleaning and sanding for a night the gearbox looks shiny again
engine headding back into its new home
intercooler position mockup
engine bay
car is now back in the garage so that i can work on it when its raining and work late into the night.
computer is all wired up now and just need to setup the link before it can start.
been working on making the aluminum half size radiator fit. had to remove the old bottom radiator mount and hack some of the side pannel off, then cut the outlet off so that it wouldnt hit the engine mount. just need to find someone to weld up the hole and make a new outlet and make up some brackets to hold it all in place.
old
new hacked area
fitment (almost looks stock)
shouldnt have problems with cooling now.
down pipe half done
been finishing up the exhaust for the past week and finally got it all done today
not bad for my first exhaust system and first time welding anything other than bits of scrap metal together. heres come close ups of some of the welds
ended up using a big fart cannon because i couldnt find a low key looking muffler that would fit for a decent price. got this one for 35 and its a genuine rsr one in pretty good condition considering its off a honda.
also got the intake plenum back from the powder coaters as well
finished up the intercooler piping today and relocated the battery into the boot, bov and air intake temp sensor welded on. not too much more to go.
mounted oil cooler behind grill and also mounted the radiator fan.
also it lives now
VIDEO
all finished now and getting tuned, as it was getting tuned turned out the cas was sending out bung signals and clutch is slipping at anything over 11 psi. So Im looking for a 20v dizzy and got a clutch in the mail as we speak/type. still managed 180kw@11psi before clutch starts slipping.
dyno plots
pics of the mostly finished engine bay
and the next upgrade for the car
they are off a LN30? hilux, will need a adaptor bracket made up and also some custom brake lines as they dont have the usual banjo bolt but have one of those flared nut things (any one know the name of them?).
new goodies
3000lb pressure plate and a 6puck ceramic/organic clutch plate, jun light weight flywheel and arp flywheel bolts
comparison of old vs new flywheel. 5.5kg compared to 4.5kg.
all back in place
new power figures
managed to get 260kw on 20psi but that was with injectors on 100% duty and also with retarded ignition timing.
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 03-12-2009, 06:26 PM   #2 (permalink)
new brackets
the outer fins on the caliper hit the inside face of the spokes so i will need to mill them off then just need to get some new lines made up
on the way home after passing some cops doing some speed checks with the laser gun and pulling people over, i get past the commotion and think to my self "hahhahaha suckers that what u get for speeding". i get to an t intersection. it was green so so i carry on then a car runs a red light and slams into my door.
it wasnt her car, she had no insurance or a license.
got a new car to plonk the turbo engine
old engine out
16v small port from the gti
removed the battery tray
modified the radiator supports and some sports of rust and managed to get the engine before i packed up tonight
the finished product;
managed to finish in time for the drags. only managed a 13.9 due to the lack of traction and slow ass reaction times. was a good learning experience and should be better next time round
went to the drags on the 27th with some better tires and managed a 13.40s 1/4 mile. still no traction in 1st so my 60ft times are still pretty average. tried taking off in second gear but it just stalled on the start line or bogged. so next time ill get some full drag slicks and see how that goes.
http://www.youtube.com/watch?v=WpgcizLDuE8
my late Christmas present to my self;
a set of 800cc SARD injectors, got them for $225 each which is quite reasonable and considering the price of parts is expected to go up due to the dollar i think it was a wise decision to buy them now. Also it means that buy the next drag meet i will have more power to play with since im going in for a tune next week.
New power figures on 22psi of boost
next is to save up a bit more for race gas and go for more boost.
got tuned on Q16 fuel (similar to C16, slightly more stable on higher boost)
340kw on 29psi
365kw on 32psi
unfortunately turbo compressor went pop and disentigrated damaging the backing part of the compressor housing. so time for a new turbo and stick to 29psi.
graphs of latest tune
on a side note from all the recent destruction, I've converted to evo coil packs and igniter and it has performed flawlessly.
pieces removed from intake system. pile on the right is from the intercooler piping straight after turbo and pile on left is what was in the entry tank of the intercooler. after intercooler there was pretty much nothing left.
cars all back together now and took it for a "test" run. now spins up in third on the motorway and is just too fast to be on the streets for any sane person (only running 29psi btw). the "test" run really highlighted the inadequate brakes and suspension i have it sor of floats around when boost comes on.
when i was putting the silicon joiner back on i noticed some bits of the compressor embedded into the joiner, and also one piece managed to punch a hole right through the joiner.
also heres a wee vid of the car i just took http://www.youtube.com/watch?v=H_kYrjtLAJc
Old 03-12-2009, 08:00 PM   #3 (permalink)
View rolla_pr's Photo Gallery
Nice!!!
Those are the 4agze pistons and rods holding up to 29psi???
rolla_pr is offline   Reply With Quote
Old 03-12-2009, 08:34 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Sweet build... I love the AE92 FX, wish they had brought it to North America.
Old 03-14-2009, 04:46 PM   #5 (permalink)
Danno
View 89yotarollagts's Photo Gallery
so how did your turbo fail ?
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 03-14-2009, 10:19 PM   #6 (permalink)
stock pistons and rods are holding up fine, and as to the turbo failure there are different theories. one is that the nut became loose allowing the comp wheel to move around and contact the wall shattering. another is that it just reached it mechanical limits with a small piece coming off or cracking making the whole thing unbalanced, at those high rpm its will just self destruct if its unbalanced.
Old 02-01-2010, 11:22 PM   #7 (permalink)
some updates to the car
Originally Posted by gasman
went to the drags today and bought my full slicks allong and they picked up on them and told me if i ran them i get the boot.
so i had to run my road tyres. first run i still had the silencer plugged in the muffler and tires fully inflated. the time slip says i got a 12.4 but i wouldn't trust it since it also says my 60ft was zero.
second run i prepped my car a bit better and got a 12.9
Vid
third run the turbo crapped out during either the burnout or the launch and ran at 16sec 1/4 in na form.
Vid
pics of the damage.
and the end result for the drive home:
got a new turbo, a Masterpower T58; same one as bazda.
also plumbed back the wastegate so i could get a cert and wof
i couldnt fine one of those small flexi's so bought a 200mm long one and chopped it down, looks a lot cleaner IMO but it was a bitch to weld, heres some pics of me dissecting the flexi
cut off the end sleves
cut the outer braiding off below the spot welds
pulling off the brading
and cutting off a smaller section
new tune with new turbo and new plenum. basically the same as it was but with less broken turbos.
Results:
bit of an update.
went to the drags back in november but ended up eating my gearbox and clutch started to slip in 4th gear on the 358kw tune.
managed a 13.3 and a 122mph trap speed on semi slicks.
after towing it back home it sat in my driveway untill mid jan of this year when i pulled off the box and clutch.
heres what i found:
the kevlar side is just down to the rivets but the ceramic side still has some meat left.
one slightly cooked and gauged pressureplate
one mildly cooked flywheel but no gauging.
so i pulled it all off and got the clutch plate rebuilt with ceramic pucks on both sides and reinstalled it
as for the gearbox im going to be running a aw11 box with a mechanical lsd.
heres some pictures of the conversion process to make it work with a ae92 shifter. it uses my old shifter assembly and to make that work i had to blank off the old shaft hole with a 28mm frost plug and drilled and tapped two new holes for the shifter linkage.
with my old gearbox i cleaned it up using a wire brush, wet dry sand paper and a whole heap of elbow grease this time around i went in search of some hydrofloric acid to chemically clean it but couldnt find any.
while searching for the acid i came allong some oven cleaner and since it says do no use on aluminum it must mean that it eats into it which is just what i need so i bought that and sprayed it all over the gearbox let it sit for a while and washed it off.
it worked well with the thinner corrosion and heavy corrosion just required a second application allong with a light scrub.
with the gearbox reinstalled i also reconfigured some plumbing and fixed up some wiring and also welded in a new bracket to mount my honda city overflow onto the chassis side rail under the airfilter. the overflow was previously cable tied to some hole over by the wiper motor.
nex on the to do is a cert for some BC coil overs i installed, then i can be legal once again.
Old 02-02-2010, 04:57 PM   #8 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
That's insane!!! It's putting out some VERY respectable figures. Sorry to hear about your white Corolla, good to see that you kept soldiering on though. Your car is a true inspiration. Lookin' forward to seeing a video one day .
Old 02-02-2010, 06:13 PM   #9 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Wow!!!
If I am reading those dyno charts right, it is puting out 2008 Nm, and 385 kW.
From the conversion charts I have found, that converts to 1480 ft/lb and 516 hp.
THAT IS INSANE!!!
WOW!!!
I am impressed.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-03-2010, 02:42 AM   #10 (permalink)
theres a couple of video under my youtube account name "justinsue"
Originally Posted by Donald View Post
Wow!!!
THAT IS INSANE!!!
WOW!!!
I am impressed.
that torque figure is measured torque at the wheels so divide that byt the final drive and 4th gear ratio of a e58 gtz box and you will have the torque at the flywheel
Old 02-03-2010, 12:30 PM   #11 (permalink)
Donald's Avatar
Ok. But that is still over 300ft/lb (I think).
I still say WOW!
I think I need to slap a turbo on my 7A-FE.
Old 02-11-2010, 01:48 AM   #12 (permalink)
Full Throttle
I just noticed that you have it for sale on TradeMe! . Hope it goes to a really good home.
Old 02-12-2010, 03:12 AM   #13 (permalink)
ELUSIV Rolla's Avatar
View ELUSIV Rolla's Photo Gallery
when ya did the LN130 calipers, did you just use standard size 90 series discs? how hard to do those brackets too? get them CNC cut? i was lookin at doing the same thing myself, mainly to fill in the wheels rather than stopping power. f**kin' sweet car bro, doin Kiwis proud. any help would be awesome, i would have given it a new home if i had the cash =(
(ELUSIV)
ELUSIV Rolla is offline   Reply With Quote
Old 03-10-2011, 09:20 PM   #14 (permalink)
View scarface4lyf's Photo Gallery
Australia
"Do not use on aluminium"
*uses on aluminium*
That's the spirit!
scarface4lyf is offline   Reply With Quote
