distribtor rebuild help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2009, 05:35 PM   #1 (permalink)
View AG1380's Photo Gallery
Unhappy distribtor rebuild help
Hi folks, I have a 89 corolla wagon, carbureted engine, with almost 200k miles. The distributor is leaking oil past the internal oil seals, so the oil is ending up inside the distributor. I located a seal rebuild kit at KBOX engineering, but in order to do the rebuild it would appear that I need to remove the shaft pin that holds the drive piece on the end of the shaft. How do I get the distributor apart? I have tried to use a drift and press the pin out, rather than hammer on it and spread out the end of the pin, but it won't budge. Alternatively, is there a reliable source for a rebuilt distributor?
Thank you, 'o most wise in the ways of the Corolla.
AG1380
AG1380 is offline   Reply With Quote
Old 03-17-2009, 02:08 AM   #2 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
If you can't remove the pin, try taking it to a machine shop or engine rebuilding shop. They usually have ways to remove stuff like that.
DCM is offline   Reply With Quote
Old 03-17-2009, 03:06 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
the pin is tapered, or I know for sure larger on one end. Make sure you aren't trying to push the larger end through
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 03-17-2009, 06:22 AM   #4 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
I used a Kbox kit on my 3S distributor last year. I used a bench vise to press it out. They are stuck in there pretty damned hard.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 03-17-2009, 09:55 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
its not tapered.. I made my own tool from a bicycle chain breaker to push the pin out and back in
Old 03-17-2009, 10:17 AM   #6 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Yep, one end has beveled edges but the diameter doesn't change. It's just wedged in there super tight and is a very hard piece of metal.
Old 03-17-2009, 09:31 PM   #7 (permalink)
thank you
Thanks for the advice, I'll try the bicycle chain tool. It's good to know that it is removable, now I feel that I can go after it with a little more confidence.
Old 03-18-2009, 04:19 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
You'll have to mod the tool... Otherwise a press will do it fine too.
Old 03-18-2009, 04:38 PM   #9 (permalink)
Gameroom cash: $134355
This is interesting.....
on a 4age dizzy I'm able to get the pin out.... but an FE style dizzy (3 I had) I couldn't press nor drill (tried 8 different types of bits) the pins out..... I was trying to make a custom 20V dizzy to work with FE or GE electronics but got stuck there....
good luck getting it out. Try a machine shop....
