If you experiencing lock ups at low brake pressures, bleed out your brake lines and put in new fluid. You may have moisture in them. Rust is not hard enough. Your pads will clean them away easily after a few stops.
As for the bushing/ mounting sleeves, fine grit sand paper should do. Mine were stubborn as well. Sand it a bit to clean it to a somewhat shine, use a good brake lubricant and good to go. They should slide smoothly with little pressure. Might want to check your piston as well. The seal may not be backing the piston far enough from the rotor.
And it's likely your rotor. Replace them or machine them, should be fine. Suggest using ceramic pads, if you're not already using them. They perform very well and dissipates heat better... they last longer, too! At least for me, surprisingly, I do hard brakings half the time. Heat can cause your rotors to go from smooth to hell, experienced that with Autozone cheap $20 semi-metallic pads that almost caused me to run a red light at 80mph cuz they heated up badly and gave me a bull ride afterwards. And then to blame for the curb I slid into last october.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
