I'm not sure exactly as I have yet to do mine, but I do know:
If you have a 4AF/Carb motor, you need to get the fuel lines swapped to fuel injection, gas tank, and the fuel pump that goes in the tank. 4AF/ Carb motors have their gas pumps on the motor.
Secondly, 4AGZE's have intercoolers on top which the regular hood of a ae92 will not clear. Either get the levin hood which has a factory scoop or diy.
Thirdly, wiring harness and ECU.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
